Author Topic: Volt light stays on- no charge  (Read 37403 times)
« on: September 30 2026, 02:14:55 PM »
So after waiting 7 weeks for an actuator bracket to be welded up for my new turbo with S cover from Precision (thats another story)  I warmed up the car all good shut it off & few mins later start it & the Red Volt light stays on? Battery slowly losing charge so I'm charging it now. I unplugged the Brown wire to Alt & the light goes out but still no charge? I think I have a Dash Bulb plug or even maybe a long shot Caspers Field Fix Plug but I'd like to know the real issue so do I pop the Dash Cover first? The bulb stays lit so it works Thanks
« Last Edit: September 30 2026, 02:57:58 PM by Just a Six? »
Re: Volt light stays on- no charge
« Reply #1 on: October 01 2026, 07:44:39 PM »
Use a old  ice-pick style  test light. Start the car, clip the alligator clip to pos + battery and punch/prick the test light into the brown wire at the alt plug.  That will bypass all the wiring going to the dashboard. If it don't charge then alt may be bad and if charges check the wires going to dash. Also make sure the red hot terminal has voltage the goes to the starter. It's been awhile but I think there's a fusible link near the starter.
« Reply #2 on: October 01 2026, 08:54:08 PM »
Ed thanks fpr the info. I have the dash 90% out & will get it done tomorrow. Ordered a Caspers Field Fix for now but want to look at the board. I'll try your ideas & there are 3 fusible links that I replaced 20+ years ago. lets see how it goes?
« Reply #3 on: October 02 2026, 12:56:05 PM »
So I bypassed the wires with direct POS to Brown Plug & no change. Shit!
Hard to believe the Alt just died? I rebuilt it 50k miles back..
Just thinking?? but maybe buy a rebuild kit if I can find one at reasonable price.
Fusible links are a PITA to trace Don't remember where they go? Maybe on Steve's site.
Lets see how the afternoon goes. Cheers!
« Reply #4 on: October 02 2026, 02:14:05 PM »
I assume you used your test light to go from the POS battery to the alt brown wire?  You need the bulb to light in the test light to take the place of the dash board  charging light. Take the alt off and have it tested at one of your large auto store like big moose auto center :D
« Reply #5 on: October 02 2026, 03:43:55 PM »
Big Moose! lol Yes I have 2 hot boxes from trunk mount on welders cable! The light lit up so if it died that will sure be a surprise. It was just at idle for 2 mins maybe 10x over the few weeks then poof! cars been down since July 1st but got lots of work done to it. The dash is out but the instructions leave out some pretty important tips to know. Alt only been back on the car for a month! back out it comes & I'll let you know. Thanks Ed
« Last Edit: October 02 2026, 04:19:40 PM by Just a Six? »
« Reply #6 on: October 02 2026, 06:21:32 PM »
Soon you will have 10 feet of snow and you can put it off until next year.
« Reply #7 on: October 02 2026, 06:26:26 PM »
If its like last year then you're right on the $$   :O
I hope its more of a snow in December or a green Christmas.
« Reply #8 on: October 05 2026, 06:43:33 PM »
Alt is toast being rebuilt have it tomorrow. Not bad its the original unit chromed by Bowling Green Customs way back when. Still looks like new!
« Reply #9 on: October 07 2026, 03:43:55 PM »
Shit! rebuilt alt & still not charging? I put test light to Exciter while running & the light Flashes for a second at most then nothing.
I do it again same thing quick flash & nothing.
The Volt light was staying on before alt rebuild but now it doesn't even light up key on? dash is still half apart but I'm putting it back together tomorrow.
I have a Caspers Field Fix coming. I have No Idea what to do next?
« Reply #10 on: October 07 2026, 07:47:37 PM »
When I had one that would not charge and the light was not working, i usually just put a dash light bulb in the wire going to the alternator and connected the wire to a source that was hot when the key was in the run position.
That way the bulb came on just like the instrument panel did and went off when the alternator charged.
Did this under the hood.
« Reply #11 on: October 08 2026, 01:24:56 PM »
Steve thanks that would be next But I found the issue. Alt was repaired & installed but the Dash wasn't put back together so as soon as I popped it into place All Good 14.4 volts! This car has been down over 3 months & Finally its good to go & test out my new turbo! Thanks Ed & Steve you guys are the best when it comes to this shit!   :cheers:
« Reply #12 on: October 08 2026, 07:42:43 PM »
We are also experts in marriage advice :icon_eyes:
« Reply #13 on: October 08 2026, 09:52:45 PM »
Always takes a couple before you find one that will put up with all your garage & car time!    :D
« Reply #14 on: October 09 2026, 12:37:37 AM »
Practice brings results
