Author Topic: A little story about my TR.  (Read 8796 times)
« on: October 11 2006, 09:31:59 PM »
First off - I'm ashamed. :(
I haven't driven or worked on my TR since April, since it was broken into and the steering column smashed. The only reason they didn't get it was my hidden fuel pump relay switch.
Reckless Rob
Offline TSM Girl
Re: A little story about my TR.
« Reply #1 on: October 11 2006, 09:38:17 PM »
They should not be giving you a problem for that.   Good for you!  Glad it started and you moved it back to the same spot!
Donna
"Stupid people should NOT breed!"
« Reply #2 on: October 11 2006, 09:42:58 PM »
Quote from: "TSM Girl @ Wed Oct 11, 2006 8:38 pm"
Offline Be4u
« Reply #3 on: October 11 2006, 10:09:12 PM »
I hope the old wombats dont decide to be wenches and have your cah towed.
Save the bumper fillers!
Move to Canadia!
« Reply #4 on: October 12 2006, 07:54:36 AM »
In 1996 some fuckers broke my column and tried to steal my car.  I had to drive it for 3 month starting by pulling the lever in the column that they had left exposed.
« Reply #5 on: October 12 2006, 08:34:17 AM »
Quote from: "Be4u"
If they do, I will sue them. I checked my rental agreement, and basically, as long as the tires aren't flat, and it has a valid tag - they can't do much about it.
Quote from: "Top Speed"
THat's how I have to start mine - with a screwdriver, pulling up on the lever.
Bastards.  :mad:
