Author Topic: burning oil  (Read 6201 times)
burning oil
« on: June 09 2014, 11:39:22 AM »
Well out of the blue ( no pun intended) it started smoking this weekend? My question is can I run it by-passing the turbo, so I can determine if its the turbo pushing oil in or a worse problem? I was just going to plumb it from the MAF to the intake, stay out of boost obviously, and see if the smoking stops. Also was going to put a white rag over the output of the intercooler and see if it gets oily?
Any suggestions?
Re: burning oil
« Reply #1 on: June 09 2014, 02:12:54 PM »
Why not look at the inside of the pipe going to the throttle body and see if is oily? Also remove the maf pipe from the turbo, grab the nut that secures the compressor wheel and check the out and in movement on the shaft.  Should be imperceptible or almost imperceptible. Then check lateral movement. Wheel should not touch the housing.
Steve
Re: burning oil
« Reply #2 on: June 09 2014, 02:17:12 PM »
Will do. Thanks!!
Re: burning oil
« Reply #3 on: June 10 2014, 02:04:49 PM »
Oil in pipe and can move impeller shaft in and out 1/8 inch  :( So looks like I need a turbo, with my current equipment what would you recommend? Also where to purchase? Assuming they cant be rebuilt?
Re: burning oil
« Reply #4 on: June 10 2014, 07:50:24 PM »
It's dead. 44 and 49's have been replaced with a new, similar model... See full throttle speed.  Or,  yes, they can be rebuilt
Steve
Re: burning oil
« Reply #5 on: June 10 2014, 08:28:56 PM »
Contact Bison on the other board. He'll tailor make you one...and he won't push the BB version down your throat.
