Author Topic: 208/208 cam installed  (Read 31490 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« on: May 31 2012, 04:32:49 PM »
installed my new cam, lifters, timing chain, and oil pump on friday 5-25-12. went cruising saturday and sunday. it seems to not have the get-up that the other cam had but track time will tell. vacuum went from 14 to 17 with the new cam, still seems low but its running pretty good
Re: 208/208 cam installed
« Reply #1 on: May 31 2012, 05:06:10 PM »
It will be weaker at high rpm, but, it should work better with your turbo, I suspect.  Your tuning may have to change
« Reply #2 on: May 31 2012, 05:13:17 PM »
Did you back the alky off because you are only running 20 psi of boost...?
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #3 on: May 31 2012, 08:05:40 PM »
no i havent adjusted anything yet, just kinda made some short WOT, and didnt have any knock, maybe tomorrow i will have time to get some scan #s and tune from there
« Reply #4 on: May 31 2012, 08:59:36 PM »
if you have the alky on the suggested default settings, then turn the boost up a couple of pounds...if no knock, turn it up two more for a total of 24
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #5 on: May 31 2012, 09:09:34 PM »
knob is set on 6 but the initial is set to turn on at 10 psi of boost, so i will turn the boost up
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #6 on: May 31 2012, 09:11:01 PM »
do you suggest that i turn the initial setting back to default (6-7 psi) for this cam
« Reply #7 on: May 31 2012, 10:11:38 PM »
I would leave the boost turn on point where it is...alky will kill the spool if it comes on too early.  I might even put it to 12
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #8 on: June 04 2012, 04:48:41 PM »
went to the track, best time was 12.73 @ 105mph, --- 23# boost, alky on 5, timing in first and second @ 132, just a lil slower than the my time with the other cam which was 12.53@ 107mph
« Reply #9 on: June 04 2012, 07:00:34 PM »
post your time slip so we can see the short times, 1/8 mph, etc
« Reply #10 on: June 04 2012, 07:29:44 PM »
Here is my problem.  That cam is about half way between what you had and the stock cam.  It is an easy ten second cam if all else is right.
Your mph is low...I would have expected closer to 110 mph with that et.   Instead, your car is running about like a stocker instead of one that has ported heads and a good cam.  So I wonder about the turbo that is on the car because it seems a bit less than a stock turbo on an I C car from the performance.  Speaking of the intercooler, what intercooler is on the car?  Is it a stock intercooler from an 86/87?
The vacuum is about right for that cam.
Also, what rpm is the tranny shifting at and are you going thru the quarter in third gear?
« Reply #11 on: June 04 2012, 08:10:40 PM »
As Steve said something really wrong to run those times.  Need more info to try and help you out.   I ran better times 20 years ago bone stock with a Kenne Bell chip.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #12 on: June 05 2012, 06:26:09 PM »
60'-1.866, 330-5.254, 1/8-8.129 @85.15, 1000'-10.63, 1/4-12.76 @105.07
the intercooler is a front mount , as for RPM i dont know, i dont have a tach and scan master is to slow. and yes i am in third at the trap.
« Reply #13 on: June 05 2012, 07:10:35 PM »
what kinda front mount?
It only picked up 20 mph in the last half...I would have expected closer to 24.
Tell me about this turbo again.  Where did it come from?
How about the valve springs?  Did you replace them?  Or know what kinda pressure they are putting out?
Did you notice your O2s on the top end?
« Last Edit: June 05 2012, 07:24:00 PM by Steve Wood »
Offline gbsean
« Reply #14 on: June 05 2012, 07:55:48 PM »
also what gas you running,,,assume it is 93 octane and not 116....did you try a pass with no alky...
