Author Topic: 208/208 cam installed  (Read 31491 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
Re: 208/208 cam installed
« Reply #15 on: June 05 2012, 08:03:08 PM »
also what gas you running,,,assume it is 93 octane and not 116....did you try a pass with no alky...
running 93, turn the alky down to 4 and started to knock, so i went up to 5 and it was ok.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #16 on: June 05 2012, 08:09:26 PM »
what kinda front mount?  gn1 performance extreme
It only picked up 20 mph in the last half...I would have expected closer to 24.
Tell me about this turbo again.  Where did it come from? stock upgraded 85 turbo. limit engineering
How about the valve springs?  Did you replace them?  Or know what kinda pressure they are putting out? I didn't replace the springs, from the paper work i have from the previous owner the spring suggested for the cam were 100# closed and 234# open. assuming that he put what was suggested 12 years ago, that is what is in there
Did you notice your O2s on the top end? 753 at the trap
Steve I really think that this turbo is holding me back, being that i have alot of compressor surge something tells me that it is working to hard
Offline gbsean
« Reply #17 on: June 05 2012, 08:11:33 PM »
something is wrong was running 12.5's with old skool ta49 and 009's at 18#'s with 3000 stall in a 4200# car with my fat arse in it...
« Reply #18 on: June 05 2012, 09:13:08 PM »
Well, compressor surge is typical of some turbos and intercooler combinations so I don't think you can take that as a sign of the turbo working hard.  I have a Craig 45 out in the shop that will shake the car apart at very light throttle, but, it is a running fool at wot.  the 45 is equivalent of a 63E from others.
Now, I don't know what an upgraded hot air turbo is equal to, but, I suspect it is pretty small.  With that cam and ported heads, that thing should really start making some power around 4500 rpm IF the turbo can pump the air.
Your O2s are about right and it will take a bit more gas to go more on the boost, I suspect.  If the turbo is too small, it will not respond to more boost, I think.
Would not hurt to pull a valve spring and test it.  As old as they are, I would guess they have lost quite a bit of pressure and that can make one lay down in third as they rev slower.   I would like to see 85# or so.
What stall converter are you running...or what does it brake stall against the pedal rpmwise?  Thinking what kind of turbo would work with it.
There is a couple of tenths in your short times to be had, but, right now, we need some mph.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #19 on: June 05 2012, 09:40:28 PM »
i did not notice any difference from 20psi to 24psi, the converter is 9 1/2- 2800, I dont know the rpm it will stall but at 3 psi of boost it wants to move the car or break tires.
« Reply #20 on: June 05 2012, 09:53:53 PM »
sounds as tight as the 9.5" that I have...it is supposed to be 3400 but it ain't happening.
If you saw no increase, then you are out of turbo unless the springs are bad and I doubt they are that bad....but I cannot be sure.
I would like to see at least six pounds of boost before the tires start to spin....it will depend on what tires you have and also how well the rear brakes are adjusted....Yo u can try using the ebrake to see if it will do better.
With that converter a Te44, TA49, or the new 5831 which replaces the first two.....would be a good match.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #21 on: June 05 2012, 10:01:40 PM »
i have been using the e-brake on the track to get 6-7 psi at the tree, I have to leave the car alone for awhile the funds are low untill next near, so for now i will just enjoy crusing. Thanks guys
« Reply #22 on: June 05 2012, 10:03:43 PM »
damn sure understand that!  Has the "drivability" improved outside fo the turbo surge?
« Reply #23 on: June 06 2012, 08:02:53 AM »
Could be major issues like trans slippage/flaring, valve springs,turbo, or just tuning. What was timing set at? Your 1.8 60ft time is not bad to start with. Helped many with a lot worse and still hit the 11's.  Did you check and see if your getting full throttle opening with the gas pedal?  What is a upgraded 85 turbo? little more info on that.
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #24 on: June 06 2012, 12:32:34 PM »
 yes Steve it does drive better, It really gets up better without any boost
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #25 on: June 06 2012, 12:35:59 PM »
Timing is at 132 on scanmaster, I am getting full throttle open on the blade, the turbo was upgraded buy Limit Eng. http://www.limitengineering.com/buick  click here
« Reply #26 on: June 06 2012, 02:48:53 PM »
Strange, that turbo is listed the same flow as a 44 or 49 so it should not be laying down on you if all is good.
Someday when you are bored, pull a valve spring, or two, and see what they are doing
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #27 on: June 08 2012, 02:21:08 PM »
I dont get bored enough to want to pull a head to check springs. but i may have to
« Reply #28 on: June 08 2012, 02:24:53 PM »
Why would you pull a head?  Remove the rocker shaft, Shoot some air in the cylinder, pull the spring
