Author Topic: powermaster  (Read 39859 times)
powermaster
« Reply #30 on: April 28 2011, 10:07:24 AM »
Quote from: "Steve Wood @ Thu Apr 28, 2011 7:52 am"
tell us about your hydroboost install
Yes please.
Where did you get the setup? How hard to install?
DETAILS MAN!!!   :rolleyes:
Offline Jordan_J
Re: powermaster
« Reply #31 on: April 28 2011, 02:19:56 PM »
The setup was very easy. I found the post on TB.com originally and kinda followed it but I liked the way this guy set his website up a little more.
http://www.cedarcrestspeedlab.com/techarticles.html?col7=open#CollapsiblePanel7
It was pretty easy though just a little time consuming especially under the dash but it wasn't too hard there as long as you are a little flexible.
I opted with the speed bleeders he used in his install as well and they are definitely nice especially if you plan to bleed by yourself.
I ordered my booster from Rock Auto and ate the core fee because it wasn't too much. And I ordered my master cylinder, pressure lines, and return line from Advance Auto because I work there and get a discount. I would call around though and see who is the cheapest in your area it wasn't very much either way for the parts I got at work. Rock Auto had the cheapest price on the booster and O'Reilly was the only other place to carry it I found here.
Be sure the paint the master cylinder too. Mine is starting to rust a little bit where either brake fluid got on it or I just didn't paint it thick enough only in a few spots though. I'll touch it up later.
I bench bled the master and then threw it on and bled the car it didn't take too long although I had a leaking line at the master so I had to replace it after a bit of troubleshootin g.
Taking the pedal off and putting it back on was probably the hardest part. You use the same pedal at the Powermaster though so if you're converting from that it's great.
The setup makes a little noise but it gets quieter at first. I haven't tried to hold any boost yet I'm just making sure some other things are good to go before I do plus I'm waiting to get my MT's mounted anyway. I'll let you all know after it stops raining on a daily basis how it does.
87 Turbo T - 4.1 484 block bored .030 over, Champion ported irons with ported intake, RJC power plate, Elgin 214/224 cam, 6776 turbo with RJC boost controller, stretched SLIC, 3\" THDP, Pypes dual exhaust, 4\" MAF pipe with 14\" K&N and Z06 MAF, 60# Mototrons, hot wired Walbro 340 with KB-BAP, Translator Gen 2 and Extender Extreme chip, Mike Kurtz built 200-4r, PPC 3200 stall, UMI upper and lower control arms, passenger side airbag, any hydroboosted.
20# Boost at 20* timing on 93 octane. No track times yet.
Alky install in progress.
powermaster
« Reply #32 on: April 28 2011, 03:56:21 PM »
Thanks for posting the link...you are a much better guy than TB 3 who has been promising to do a write up for years!
Offline Jordan_J
powermaster
« Reply #33 on: April 28 2011, 11:29:15 PM »
No problem. I didn't take near the pictures that the fellow at the link I took did. I just took more of a before and after type deal.
Cardone promo
« Reply #34 on: May 10 2011, 08:12:54 AM »
Quote from: "ULYCYC @ Tue Apr 26, 2011 3:40 pm"
If you shop around you can find the Cardone units for $400.
powermaster
« Reply #35 on: May 10 2011, 08:37:49 AM »
Code 'EMD5' will get you $20.00 off $50.00
Not sure if these will work:
http://www.buxr.com/coupons/advance-auto-parts
powermaster
« Reply #36 on: May 10 2011, 09:00:44 AM »
Cool, a coupon thread might make sense, Ford forums always seen to have Rockauto discount codes posted.
Re: powermaster
« Reply #37 on: May 10 2011, 11:04:00 AM »
Just check the webpages for Advance, Autozone or others before you go to the store. Advance now has 20% off total order under promo code P20
Re: powermaster
« Reply #38 on: June 07 2011, 12:44:33 AM »
Sometimes I wish for a paper copy (vs pdf) of the manual-
How is power fed to the powermaster motor?
Does it have it's own breaker somewhere?
powermaster
« Reply #39 on: June 07 2011, 09:10:01 AM »
pwr brk fuse and rlys fuse
