Author Topic: powermaster  (Read 39860 times)
powermaster
« Reply #15 on: April 26 2011, 08:42:19 PM »
or idiots?  :D
Offline Wrecked Em
    • http://www.hotairbuick.com
powermaster
« Reply #16 on: April 26 2011, 08:51:58 PM »
I like the hydroboost. If the 87 was not already converted to vacuum, I would install a hydroboost system. It still may get one down the road. My 85 is hydroboost and it has performed flawlessly as did the 85 GN I had before this one.
powermaster
« Reply #17 on: April 26 2011, 09:24:38 PM »
tb3 installed one...now, I don't think he has ever, or will ever, drive his car.  It is mainly a prop for his photo endeavors.
Lotsa astrovans and others with hydroboost.
powermaster
« Reply #18 on: April 26 2011, 10:20:30 PM »
Quote from: "Steve Wood @ Tue Apr 26, 2011 8:24 pm"
powermaster
« Reply #19 on: April 27 2011, 10:04:44 AM »
Okay, now I will show my ignorance. Is hydroboost changing it to a system like out of an S-10?? I thought I read about that before. I'll have to start doing some searching on the issue and get educated. I take my wife and son alot in this car and I dont need any braking drama.
Thanks guys!!
powermaster
« Reply #20 on: April 27 2011, 11:26:11 AM »
Quote from: "Shimy87 @ Wed Apr 27, 2011 9:04 am"
Thanks guys!!
Hydroboost is the system used on the NA 84/85 turbo Regals (and other GM trucks, etc) it uses the power steering pump and pressure to provide the boost for your brakes.
Expensive new . .
http://www.powerbrake-drivetrain.com/servlet/the-212/85-86-87-BUICK/Detail
Offline Mountain GN
  • Newbie
    • http://www.gmls4.com
powermaster
« Reply #21 on: April 27 2011, 04:45:22 PM »
I converted to vacuum a few years back and haven't regretted it for a moment.
We were replacing Powermaster crap annually, and the vacuum conversion completely eliminated THAT problem.
We got out setup at MP Brakes complete for under $400.  We don't have any junk yards nearby, so this was the best way to go for us.
2006 Impala SS; Factory Navigation, Trinity, DiabLew Tuned with Lew\'s Custom 87 Tune, Big Ass Tranny Cooler, Triple Edge Performance valvebody, Precision Industries low-stall converter, TransGo S/K, CAI, catless dp, custom cat-back with SpinTech mufflers, Optima Red Top.
2009 Saturn VUE XE AWD
1987 Buick Grand National; Family owned since June 1987.
TE-44, MSD 50 lb injectors, AlkyControl, BstC, GNX bracing, Hot-wired Walbro 340, TurboTweak Chip, Hooker Exhaust, \"custom\" cat, \"modded\" Kenne Bell Ram Air, stock longblock.
Offline Wrecked Em
powermaster
« Reply #22 on: April 27 2011, 06:16:35 PM »
Quote from: "SuperSix @ Wed Apr 27, 2011 9:26 am"
Thanks guys!!
What is an NA 84/86 turbo Regal?
powermaster
« Reply #23 on: April 27 2011, 07:08:37 PM »
Quote from: "Wrecked Em @ Wed Apr 27, 2011 5:16 pm"
Thanks guys!!
Whooops!
And  :finga:
Offline Wrecked Em
powermaster
« Reply #24 on: April 27 2011, 07:26:20 PM »
Quote from: "SuperSix @ Wed Apr 27, 2011 5:08 pm"
Thanks guys!!
Whooops!
And
powermaster
« Reply #25 on: April 27 2011, 07:27:37 PM »
That is the north american special edition that was imported to Canada with Mapleleaf insignia on the valve covers.
Offline Wrecked Em
powermaster
« Reply #26 on: April 27 2011, 07:29:08 PM »
Quote from: "Steve Wood @ Wed Apr 27, 2011 5:27 pm"
Oh, that one!  :yawinkle:
powermaster
« Reply #27 on: April 27 2011, 08:53:26 PM »
And hasn't won  since 1967
Offline Jordan_J
powermaster
« Reply #28 on: April 27 2011, 11:49:25 PM »
I haven't used vacuum brakes but I will say that Hydroboost is much better than the Powermaster was. I have only logged around 30 miles on my hydroboost so far but it works great and I can safely compare it to newer car braking.
87 Turbo T - 4.1 484 block bored .030 over, Champion ported irons with ported intake, RJC power plate, Elgin 214/224 cam, 6776 turbo with RJC boost controller, stretched SLIC, 3\" THDP, Pypes dual exhaust, 4\" MAF pipe with 14\" K&N and Z06 MAF, 60# Mototrons, hot wired Walbro 340 with KB-BAP, Translator Gen 2 and Extender Extreme chip, Mike Kurtz built 200-4r, PPC 3200 stall, UMI upper and lower control arms, passenger side airbag, any hydroboosted.
20# Boost at 20* timing on 93 octane. No track times yet.
Alky install in progress.
powermaster
« Reply #29 on: April 28 2011, 08:52:51 AM »
tell us about your hydroboost install
