Author Topic: powermaster  (Read 39858 times)
powermaster
« on: April 26 2011, 12:12:03 PM »
I know alot switch to conventional brakes. I still have the original equipment but reading about failures makes me nervous. Getting car ready for another summer and the powermaster seems to make more noise than it did last year, probably just me but should this thing be making noise at all?? When you step on the pedal it makes noise for a couple seconds.
Thanks for any feedback
Re: powermaster
« Reply #1 on: April 26 2011, 12:20:31 PM »
Quote from: "Shimy87 @ Tue Apr 26, 2011 11:12 am"
That's normal - it's the motor compressing brake fluid into the accumulator. It may be either getting worn out, or you are just noticing it more now.
Even if the electrical system fails, you will still have brakes, albeit a very hard pedal.
I am seeing replacement units pop back up on auto parts sites, very expensive, but if the factory look is what you want - it may be worth it. I would swap to vacuum and never look back, but I don't care about stock appearance.
Have you ever replaced the accumulator ball?
powermaster
« Reply #3 on: April 26 2011, 12:26:59 PM »
powermaster
« Reply #5 on: April 26 2011, 01:26:17 PM »
Re: powermaster
« Reply #7 on: April 26 2011, 02:16:44 PM »
never replaced anything....ye t. The brakes work fine, I just never noticed the noise much before?!?!
Offline Turbodave
Re: powermaster
« Reply #8 on: April 26 2011, 04:39:27 PM »
When or if you need the accumulator, Kirban's unit is well priced and a high quality unit.
TurboDave EWCS(SW) USN (Ret.)
Sevierville, TN
powermaster
« Reply #9 on: April 26 2011, 04:40:41 PM »
If you shop around you can find the Cardone units for $400.  Advance has 25% coupons that will drop the price under $400 when they have the promo's
Offline Wrecked Em
    • http://www.hotairbuick.com
powermaster
« Reply #10 on: April 26 2011, 08:00:17 PM »
Hydroboost....
powermaster
« Reply #11 on: April 26 2011, 08:04:24 PM »
Quote from: "Wrecked Em @ Tue Apr 26, 2011 7:00 pm"
Hydroboost....
Vague post is vague.
Are you saying people should convert to a hydroboost system instead?
powermaster
« Reply #12 on: April 26 2011, 08:12:02 PM »
that is what he was saying :)
powermaster
« Reply #13 on: April 26 2011, 08:24:29 PM »
Quote from: "Wrecked Em @ Tue 26 Apr, 2011 18:00"
Hydroboost....
That's what's on mine. :D But it is a factory system for a HA car after all. :finga:
powermaster
« Reply #14 on: April 26 2011, 08:28:13 PM »
Some people freak when the talk about that "floating valve thingy" in the hydroboost.
Drama queens?
