Author Topic: Misaligned Cam Angle Sensor  (Read 7481 times)
Offline kma697
« on: November 12 2006, 12:19:19 PM »
Probably another dumb question but I'm a noobie so.....What problems can a misaligned cam angle sensor cause???  I am getting some detonation when I roll into the throttle and i'm thinking this could be part or all of the problem?? :sad;
DSR #420
89 TTA #602
89 Mustang LX 5.0 Vert.
03 Cobra
Offline Recklessrob
Re: Misaligned Cam Angle Sensor
« Reply #1 on: November 13 2006, 06:45:17 AM »
Quote from: "kma697 @ Sun Nov 12, 2006 12:19 pm"
Rob
Offline kma697
« Reply #2 on: November 13 2006, 09:07:13 AM »
If i let the car shift into second and gradually jump on it when i hit maybe 2500rpms the detonation will start building on the Scanmaster.   Unfortunately no boost gauge(stocker) or fuel pressure yet those are coming.  Stock TT chip for 93 octane.  I was just curious cause the car is going to the shop this week and thats one thing i will have them checking,  finally found a shop that can work on Turbo cars!! :D   I'm happy about that but I haven't received any bills from them yet either :bigeyes;  PS It was just an " in general" question.  Thanks.  I know my car needs some work as I went to the track and only went 13.92@98...stock they should do a 13.50 plus I have the RJC plate, Walbro pump, new injectors, better chip and valvesprings, plus it was stumbling on the top end of 2nd and 3rd so there is more there.  I changed the wires and the coil pack so the only 2 options left.....ignit ion module and checking the cam sensor.
DSR #420
89 TTA #602
03 Cobra
Offline Turbogn86
« Reply #3 on: November 13 2006, 10:16:19 AM »
actually these cars bone stock with a filter, the best i have seen between mine and a friends was a 14.0... so not bad. and a FP guage and boost guage are a must. u might have the boost too high or to low. that was my problem when i put my new TE-44 on. car felt slugish so i  checked EVERYthing i could think of... then hooked up my boost guage... i was at 11 psi, had the car set up for 18 or 19. u never know
86 GN-sold
87 WE4 (Daily Driver)
Offline kma697
« Reply #4 on: November 13 2006, 10:49:23 AM »
Quote from: "Turbogn86 @ Mon Nov 13, 2006 10:16 am"
DSR #420
89 TTA #602
03 Cobra
Offline Recklessrob
« Reply #5 on: November 13 2006, 12:46:41 PM »
Those aren't bad times considdering you
don't know how much boost or fuel pressure
you're running. I have a very similar setup
to yours, and I run 13.3 @ 99.69 MPH FWIW.
Rob
