Author Topic: Daveismissing!!!! Need Help!!!!  (Read 11724 times)
« on: October 21 2019, 04:58:23 PM »
I'm having no luck. So this Yamaha remote decides to die out of nowhere. Did the iPhone trick and there's no IR coming out of it. Is this repairable? And if so...what needs to be replaced. Heard it's a diode...or some fukn thing. Is the part generic?
P.S. Yes...fresh batteries.
Re: Daveismissing!!!! Need Help!!!!
« Reply #1 on: October 21 2019, 04:59:19 PM »
Checking YouTube now.
« Reply #2 on: October 21 2019, 05:03:55 PM »
There's a Yamaha dealer in town...but they're closed today. Will check with them in the morning. Think they might sub it out?
« Reply #3 on: October 21 2019, 05:18:52 PM »
I got a couple remotes here I can scrounge from.
« Reply #4 on: October 22 2019, 12:50:41 PM »
You could try to swap the IR LED - polarity has to be right and match . if it is clear plastic you may be able to see which leg had the larger metal inside or sometimes the legs are thicker at the top.
« Reply #5 on: October 22 2019, 01:06:56 PM »
I don't think most phones will pass the IR anymore - that was how they were getting the "nude " effects early days
« Reply #6 on: October 22 2019, 01:10:53 PM »
Thanks Dave. Talked to my buddy that's the long time audio tech. He's gonna have a look at it tonite. I can see the IR lite on all my other remotes with my phone...except the Yamaha.
« Reply #7 on: October 22 2019, 01:18:05 PM »
Good you did check a good one.
just testing- my Iphun blocks the IR but my dull webcam shows it clearly
« Reply #8 on: October 22 2019, 01:21:04 PM »
You did open it check that the bat contacts aren't corroded or broken solder joint where the contacts stick into the pcb, also common
« Reply #9 on: October 22 2019, 01:24:56 PM »
Yeah...had a look. My luck...is never anything that simple. The red lite comes on as soon as you touch any of the keys.
« Reply #10 on: October 22 2019, 02:25:03 PM »
Probably means the micro inside is still working so that is good.
« Reply #11 on: October 22 2019, 02:36:54 PM »
Get back to you on it when he gets a look at it. Off to the Yamaha dealer to see if they have a fix for this HDMI handshake BS going on between the receiver and TV. Currently have the Blu Ray player HDMI'd to the TV...and the optical out from the TV to the receiver for sound.
