Author Topic: Valve cover gasket?  (Read 15422 times)
Valve cover gasket?
« on: November 07 2018, 05:20:21 PM »
So the machine shop that did my 4.1 put cork valve cover gaskets on and as usual oil pours out of it! :013:
Does anyone have the part number for the rubber ones with the metal inserts?
Re: Valve cover gasket?
« Reply #1 on: November 07 2018, 07:11:57 PM »
If you have rough cast stock heads, tighten those cork gaskets down again.
Then do it one more time.    Once they take a set and mold to the heads, they'll be leak free (and reusable) for over a decade of daily driving.
It typically takes three tightinings to make them happy.
« Reply #2 on: November 08 2018, 10:28:53 AM »
I did tighten them once already.  But I really hate cork!  As soon as it gets cold out they shrink.  I remembering taking them out in pieces.
« Reply #3 on: November 08 2018, 04:53:30 PM »
Hit them a 3rd time and they'll be leak free  (unless you're running some weird ass metric cork :) )
I put a set of fel-pro corks on my GN when I bought it in '98 and never took them off until a high pressure/high temp rotary dishwasher compromised them.   If I'd hand cleaned them, those '98 models would still be on my car.
« Reply #4 on: November 08 2018, 10:21:46 PM »
I have a cork gasket on my tranny pan. Been on and off probably a dozen times. No leaks. Cork for the win!
« Reply #5 on: November 11 2018, 07:36:57 AM »
The Right Stuff. Here endeth the lesson.
Valve cover gasket?
« Reply #6 on: November 11 2018, 06:52:05 PM »
How do you get them off Brad? The shit is strong!!!!!
« Last Edit: November 11 2018, 07:18:40 PM by larrym »
« Reply #7 on: November 12 2018, 02:59:12 PM »
Crow bar.
Valve cover gasket?
« Reply #8 on: November 12 2018, 07:30:38 PM »
My buddy used it on an oil pan once hammer and a painters 3 in 1 tool was the only we to get it off.
« Reply #9 on: November 13 2018, 03:08:02 AM »
That's the only thing I use on my oil pans.
I like my X-over pipes without baked on crap.
« Reply #10 on: November 13 2018, 11:04:29 AM »
I cork gasket on my oil pan with the right stuff.  Never had a leak there but those damn valve cover gaskets are possessed!
« Reply #11 on: November 13 2018, 04:39:12 PM »
I git tired of the damn valve covers leaking.
