Author Topic: SP on scan master  (Read 8093 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
SP on scan master
« on: May 02 2016, 10:47:20 AM »
how accurate is the SP readings on the scan master?
Re: SP on scan master
« Reply #1 on: May 02 2016, 04:53:08 PM »
should be close...you can compare wide open throttle spark to what is the chip is set to and it should normally be the same
