Author Topic: rear tire  (Read 10587 times)
rear tire
« on: April 27 2016, 02:43:46 PM »
Whats the best size 15 inch slick to put on these for the 1/4
Re: rear tire
« Reply #1 on: April 27 2016, 03:19:56 PM »
Now there is an open ended question.
I like tall over wide but there are plenty of opinions on the subject. For a fairly stock combo , a 26x8 is a good jump off point. But as you produce more power and want to launch harder a 28x9 becomes a better choice, and fits in a stock fender well on a stock wheel. As you go to wider rims, wider tires can easily be the next step.
What 60' goals do you have?
Re: rear tire
« Reply #2 on: April 27 2016, 03:41:38 PM »
1.6, maybe a little better if I can. I run a 17x10 rim now with street tire. Was going to get a set of steel 15 rims and stuff as much tire as I could in there.
Re: rear tire
« Reply #3 on: April 27 2016, 04:35:22 PM »
Maybe some 15x8 wheels with a 28x9 Mickey Thompson slick. You will need a drive shaft loop if you have a good track tech and it is a good idea either way.
Re: rear tire
« Reply #4 on: April 27 2016, 05:25:25 PM »
I have one....thanks!
Re: rear tire
« Reply #5 on: April 28 2016, 05:28:53 AM »
275/60-15 is the latest trend. Little bit wider than a 28/9. 4 inch back space on the 8 inch rim
Re: rear tire
« Reply #6 on: May 01 2016, 02:05:17 PM »
28x9 on a 4 inch backspace rim.
Re: rear tire
« Reply #7 on: May 01 2016, 05:39:01 PM »
I run an air shock to get the tire off the wheel well. The 1/4's aren't rolled.
