Author Topic: Old parts and junk for sale  (Read 55097 times)
Offline gordyzx9r
  • The Sultan of Swank
« on: October 31 2014, 12:49:25 AM »
Just in time for  :114: !
It's stuff you don't need and/or don't want but will buy anyways 'cause it's car parts and it beats the crap out of buying purses and handbags and shit that your wife/GF/SO will spend your money on.  Most of it's old crap that was pulled off of my GN at one point or another as I upgraded and/or replaced shit for no reason.  But there are a few new items on the list which I've had sitting around for awhile...
So, what's in the pictures below is what there is.  If you don't see the hardware in the pic, then it's not there.  A couple of items I don't have the instructions on.
Make offers, don't forget about S&H.  I'm shipping from 36619.
If you live in/near Pensacola, Mobile, Biloxi, Gulfport, New Orleans, Baton Rouge, Shreveport, Hattiesburg, and/or near any of those places along I10/I12 I might be able to save you S&H and deliver them in person (so long as you don't need it right away and can wait a couple weeks or so until I meander into those towns on business).
 ·         2 Bar MAP Sensor
·         Air Filter Housing w/Dirty Air Filter
·         Alternator
·         AM/FM Cassette Player (in '99 I had the tape deck repaired...I think it still works)
·         Ash Tray
·         ATR Billet Oil Filler Tube
·         ATR Black Beauty 8mm Plug Wires
·         ATR Downpipe
·         ATR PCV (2)
·         ATR Pitbull Chip
·         Cam, OEM (came out of my GN with 80K miles…not sure what you’d want it for)
·         Casper’s Ground Stretcher Kit
·         Casper's Tach Tap Mating
·         Casper's VDO Converter
·         Charcoal Canister Bracket
·         Chip
·         Crankshaft Sensor (I'm pretty sure this is one of the "recalled" ones...not sure why anyone would want it, but here it is nonetheless)
·         EGR Stuff
·         EGR Stuff (see pics)
·         Fake Wood Trim for a Limited
·         Front Cover
·         Front Cover, Machined (the one with the pump)
·         Front License Plate Bracket
·         Fuel Injectors:  As far as I know the injectors are the stock injectors
·         Fuel Pressure Regulator
·         GN Wheels (2)
·         GNS Accessory Fuse Box Kit, New
·        GNS Radiator Box In Kit, New (http://www.gnsperformance.com/#!bodyframe-g-body/c15ae)
·         Horn Ring, New
·         IAC
·         IC Fan, New
·         IC Fan, Old
·         IC Shroud
·         Intercooler, old (79K miles)
·         Jack
·         Kirban’s Body Mount Frame Washers
·         Kirban’s Brake Dust Shield (4)
·         Kirban’s Reproduction Vacuum Line Set
·         Kirban’s Valve Springs
·         Kirban’s 3 Piece Front Brace Kit, used (no mounting hardware)
·         Lower Control Arms, OEM
·         Oil Pressure Sender
·         PCV (2)
·         Plug Wires (I don't know if these are original or not, they're grey and they say "Autolite" on them)
·         Poston fuel pump wiring upgrade (I do not have the instructions)
·         Prothane Urethane Body Bushing Kit
·         Quick Spool Controller (I don't know who made this...I think I ordered it off of ebay, but never used it)
·         Radiator Cap
·         Radiator Overflow Tank
·         Ramchargers Dual Fans w/Racetronix PNP Wiring Harness Kit (never installed)
·         Rearview Mirror
·         RJC Pulley
·         Starter, Mini
·         Starter, OEM
·         Stewart Warner 10K RPM Tach (never installed, I just used it when I was troubleshootin g a problem with my 8K tack)
·         Stewart Warner Fuel Pressure Gauge
·         Stewart Warner Mechanical Oil Pressure Gauge
·         Stock Front Cover
·         Stock heads Set 1 (I was told they’re leaking past the valves)
·         Stock heads Set 2 (came off of my GN w/80K miles)
·         TA-49: Rebuilt by PTE MAR 2015
·         Timing Chain and Gears, Old
·         Timing Chain Set, New
·         TPS
·         Turbo Tweak Chips (4)
·         Upper Control Arms, OEM
·         Vacuum Block
·         Vacuum Lines
·         Wastegate Vacuum Hose (2)
·         Water Temp Sender
·         Windshield Washer Fluid Tank
« Last Edit: March 08 2015, 07:46:36 PM by gordyzx9r »
Offline gordyzx9r
Re: Old parts and junk for sale
« Reply #1 on: October 31 2014, 12:50:15 AM »
Pics
« Last Edit: March 08 2015, 07:46:52 PM by gordyzx9r »
Offline gordyzx9r
« Reply #2 on: October 31 2014, 12:51:05 AM »
More Pics
Offline gordyzx9r
« Reply #3 on: October 31 2014, 12:51:48 AM »
More Pics
« Last Edit: March 08 2015, 07:47:08 PM by gordyzx9r »
Offline gordyzx9r
« Reply #4 on: October 31 2014, 12:52:33 AM »
More Pics
« Last Edit: March 08 2015, 07:48:49 PM by gordyzx9r »
Offline gordyzx9r
« Reply #5 on: October 31 2014, 12:53:18 AM »
More Pics
« Last Edit: March 08 2015, 07:39:00 PM by gordyzx9r »
Offline gordyzx9r
« Reply #6 on: October 31 2014, 12:54:22 AM »
More Pics
« Last Edit: October 31 2014, 12:58:24 AM by gordyzx9r »
Offline gordyzx9r
« Reply #7 on: October 31 2014, 12:55:26 AM »
More Pics
« Last Edit: March 08 2015, 07:39:32 PM by gordyzx9r »
Offline gordyzx9r
« Reply #8 on: October 31 2014, 12:56:15 AM »
More Pics
« Last Edit: March 08 2015, 07:48:32 PM by gordyzx9r »
Offline gordyzx9r
« Reply #9 on: October 31 2014, 12:57:12 AM »
More Pics
« Last Edit: March 08 2015, 07:40:33 PM by gordyzx9r »
Offline gordyzx9r
« Reply #10 on: October 31 2014, 12:57:51 AM »
More Pics
« Last Edit: March 08 2015, 07:41:23 PM by gordyzx9r »
« Reply #11 on: October 31 2014, 07:53:08 AM »
Hey Gordy!
I'm looking to shave some weight and interested in the mini starter and the crank pulley.  Do you know if the pulley is standard or underdrive?  How about $150 shipped to 76528?  Also, your preferred payment method.  Thanks in advance!  Jason
Offline mrneg9
« Reply #12 on: October 31 2014, 08:23:53 AM »
Interested in.  Brake dust covers, IC Fan New, Oil breather tube,  Kirban valve springs. electric fans and harness.
Would $175.00 do it to 08009  NJ.
« Last Edit: October 31 2014, 08:33:03 AM by mrneg9 »
Offline 1KWIKSIX
« Reply #13 on: October 31 2014, 08:35:07 AM »
Hi Gordy,
I'm interested in the Caspers VDO inline cable converter...
How about $40. shipped to 14303?
thanks,
dave
« Reply #14 on: October 31 2014, 09:18:19 AM »
How many miles on the stock timing set?
