Jason...what size rear tire are you running? 26" or 28". Could pull some fuel in low gear...but I'm happy with what I see. Don't see anything bad happening in the first file. Good RPM drop on the shifts. Hang on...your battery voltage at WOT in 3rd gear is 12.5...so that needs to be addressed. 2nd run shows you leaving the line at 3667 RPM's and 13.9 lbs of boost...and about 4 seconds to spool. Might wanna try leaving the line with a little less boost/RPM's...so you don't overpower the track. The two runs you blew the tires off you left the line with a little over 20 lbs of boost.Your 1/8th to 1/4 calculation is 12.3 at 107.
Not much mph for the 7.85, did you let off at the end of the run?Do they give you a 330' time n mph?how much boost are you launching at?Have you tried different pressures in the tires to get a good looking patch? Pressure you are using?Do you know what mr jake did to the trans? parts mods etc?I wouldn't lock it unless jake said it would be ok.
With the short sidewall you might think about more pressure to get the middle up. Find a side street and lay down some marks and look at them. Do the marks look even? More to the middle? Too much pressure, let some out. More to the edges? Too little pressure add some. Look at the tires to make sure they are wearing evenly across the tread. A good 60' is needed to get he best run.Trans sounds expensive but I bet it is worth it.If it isn't knocking I'd keep adding boost/fuel til it does then back it off a bit.
Long ago, Jeremy (Nocooler) was running mid-elevens on a TE-44 in a peg leg car...he put some serious air in the bag on the passenger side to hook it up
