Author Topic: fuel Schrader valve question  (Read 9907 times)
Offline tb3
« on: April 19 2014, 10:35:01 PM »
I got in a pinch and used a valve from a tire stem instead.
is it any different because of the fuel?
Offline TRICKSIXPA
  • Shiny Parts Addict!
« Reply #1 on: April 19 2014, 11:47:35 PM »
I'm pretty sure the gas will break down the rubber seals in it pretty quick. It's got to be a pretty common part.
Sent from my iPhone using Tapatalk
Re: fuel Schrader valve question
« Reply #2 on: April 20 2014, 09:22:35 AM »
favorite answer:
The rubber will deteriorate and you will watch that new car go up in a ball of flames.
http://ls1tech.com/forums/generation-iii-external-engine/1622049-can-i-use-normal-tire-valve-core-fuel-schrader-valve.html
Quote
The valve core is #88894338, retail $6.28 .
And if you're missing the cap it's #214-1044,
and #25532662, retail $5.50 .
Offline tb3
« Reply #3 on: April 20 2014, 12:53:36 PM »
That's good enough reason for me then!
I got a couple coming.
Thanks guys!
