Author Topic: Size matters  (Read 10750 times)
Offline Sixpack
Size matters
« on: December 21 2012, 06:30:18 PM »
What size tire are you all running in the rear on the street. I was running a 255/50/15 24 inch tall tire decided to go to a 60 series now 26 inch tall what u think.
Offline TWIN86GNS
  • My car is almost ready!!!!
Re: Size matters
« Reply #1 on: December 21 2012, 07:16:16 PM »
What mods are done to your car?  I assume it is an 86-87 TR and it is running well?  If it is then going to a 28" tall tire won't hurt it a bit as long as you are running mid to low 12's or better from my own personal experience.
I have run various gears in GN #1, 3.42 (stock) and they worked well, 3.90 (needed taller tires (28") to go as fast as the 3.42's), 4.88's needed 28" tall tires and using 4th gear to run the 1/4 mile, no quicker than 3.42's with 28" tall tires.  3.42's with 28" tires were quicker than 3.42's with 26" tall tires.
Good luck,
Paul Beal
beal_paul@yahoo.ca
Offline firebird_1252
  • PSI: -1
Re: Size matters
« Reply #2 on: December 21 2012, 08:18:53 PM »
on the street i like the same size all the way around. i like rotating the tires and what not.
87 GN- :D
Re: Size matters
« Reply #3 on: December 22 2012, 12:24:42 AM »
Good luck,
I have found the 28" tire ideal for most cars that have a few mods as well... length of the patch causes a noticeable improvement in bite and our cars make so much torque that the approximate 8% change in apparent gear ratio is not noticed.
