Author Topic: outbound relay  (Read 17914 times)
outbound relay
« on: December 10 2012, 06:53:39 PM »
Well it started tbs is spam rated.
They are now relaying mail.
Sad that it is coming to this.
 "vsobr @ bounce . com" this address is used all over the world. I have gotten spammed from it for a while. I know others that have also. Does not matter if you opt out or not you will get what they want to send you.
So the next thing is to sell your data and they will have lots.
Here just an example of who is tracking there upper right corner in purple.
AJ___
Re: outbound relay
« Reply #1 on: December 10 2012, 07:17:04 PM »
I've noticed pageloads have become slow as sh*t.
from the goldwing forum.
snip...
The "from" address to add to your white list is actually:it@autoforums.com
It would also be worth adding the bounce return address:bounce@vsobr.com
Because these two addresses are not the same, many ISPs and spam filters will treat these notification emails as spam.
...unsnip
« Last Edit: December 10 2012, 07:35:19 PM by daveismissing »
Offline tb3
Re: outbound relay
« Reply #2 on: December 10 2012, 08:42:16 PM »
yay
Re: outbound relay
« Reply #3 on: December 10 2012, 09:39:47 PM »
One more reason to never surf without the scriptblock extension
Re: outbound relay
« Reply #4 on: December 11 2012, 11:28:35 PM »
Agreed. But it only does so much.
AJ___
Re: outbound relay
« Reply #5 on: December 12 2012, 12:41:44 PM »
Maybe it's Adblock Plus that kills them.
Re: outbound relay
« Reply #6 on: December 12 2012, 06:18:11 PM »
I am amazed that forum is still running.
