Author Topic: terminal box  (Read 31470 times)
terminal box
« on: September 18 2012, 06:50:34 PM »
we need a small terminal box about 2" long (5 cm) that would mount under the dash and provide a terminal for engine ground, ignition 12 volts, and battery 12 volts.
After 25 years, I have so many frickin' wires spliced into things and disappearing into rat's nest of tie wrapped wiring bundles that I have no clue as to what goes where.  I have to put a jack under the under dash panel to push everything up to reinstall it and it still bulges down toward my size 12 feet.
I actually redid a lot of it a few years back but it is out of control again.  Took me an hour to get all the LC-1 crap out of the car and most of that was just trying to figure out what wires went where and where it was safe to cut.
Re: terminal box
« Reply #1 on: September 18 2012, 08:17:32 PM »
sometimes you have to break out the hedge clippers and cut out the rats nest and start over.
nothing like looking at a foot long piece of wire with 5 butt splices and 4 cut off pigtails
Re: terminal box
« Reply #2 on: September 18 2012, 09:20:51 PM »
I did that a few years ago, but, it's out of control again.
On my old Challenger, I just started wiring things they way should have done it back in the '70s instead of send a firetrap out the customer.
Re: terminal box
« Reply #3 on: September 18 2012, 09:44:56 PM »
Basically, what I want is three bus bars in a plastic box....everyth ing I see is uncovered which is inviting trouble
Re: terminal box
« Reply #4 on: September 18 2012, 09:55:11 PM »
We also need some factory supplied holes in the firewall for running stuff thru...pop out the plug and put in a grommet.  It's amazing how many wires you can run thru the speedometer grommet but, it contributes to the mess.  It's hard to find a spot to drill a hole with access from under the hood and a clear path to the interior without hitting something.
Re: terminal box
« Reply #6 on: September 18 2012, 10:11:58 PM »
Not specifically.. mainly because I was looking for terminal points and was not particularly interested in fuses....I have considered something like the Painless Cirkit Boss...tho.  But, I really want a source for a good interior ground, ign 12, and battery 12v as I said...nice and simple....
Most things leave it to you to find a good ground and not all interior sheet metal is created equal when it comes to ground quality.  Can really screw up something like a WB
Re: terminal box
« Reply #8 on: September 18 2012, 10:25:16 PM »
do you still have the page link open for that one?
Re: terminal box
« Reply #9 on: September 18 2012, 10:32:44 PM »
Re: terminal box
« Reply #10 on: September 18 2012, 10:50:13 PM »
Looks like overkill and expensive...bu t I ordered a couple...
Re: terminal box
« Reply #11 on: September 19 2012, 07:44:19 AM »
I share your frustration
There are some nice din rail parts but not really small or suited for auto use.
Fabricating Dual Screw terminal strips in a box using the ganged connector on the opposite side of the term strip is another alternative
Re: terminal box
« Reply #12 on: September 19 2012, 09:27:56 AM »
I need one for the Challenger as well....since I built a new instrument panel, I would like to wire it to something more substantial that the rotten, burned, rat chewed, repaired wiring that comprises the current dash harness.
On the buicks, I think I will mount it on the hvac box near the PL block so I can reach thru the glove box and change something without having to remove the under dash panel and try to find my way thru the maze of wiring.
Re: terminal box
« Reply #13 on: September 19 2012, 09:52:29 AM »
A hinged panel that swings down holding the distribution would be real sexy
Re: terminal box
« Reply #14 on: September 19 2012, 10:21:25 AM »
I am too old for sexy, but, functional works for me!
