Author Topic: Spitting black gobs out exhaust, INT 160, stuff in radiator...fun.  (Read 140281 times)
Offline gordyzx9r
  • The Sultan of Swank
Re: Spitting black gobs out exhaust, INT 160, stuff in radiator...fun.
« Reply #60 on: August 26 2012, 05:11:54 PM »
Yeah, that's what I figured out...the bolt stays in, lol.  It's out.  Wasn't that bad once I figured out I didn't have to take the bolt out...outta be fun putting it back on.  I took it off, took off the rocker assembly while talking to Bill on the phone.  Looked it over, I don't see anything wrong...but the what hell do I know.
Offline gordyzx9r
« Reply #61 on: August 26 2012, 05:13:03 PM »
Last pic...
Off to the store to get a torque wrench, I don't have the right one.
35 ft lbs. for the three bolts on the rocker assy?
« Reply #62 on: August 26 2012, 05:15:24 PM »
Did you run it to see if the noise was coming from the valve train?
Offline gordyzx9r
« Reply #64 on: August 26 2012, 05:41:05 PM »
I couldn't tell...I hear noises all the time.
« Reply #65 on: August 26 2012, 07:17:16 PM »
so we don't know if the noise is coming from that area, or maybe the flexplate as David suggested?
Offline gordyzx9r
« Reply #66 on: August 26 2012, 08:21:18 PM »
Alright, listened and felt the valve covers with the car running and I didn't hear or feel anything odd.  Underneath the car, it's ticking.  I taped it and will try to upload it and link to it in a bit.
« Reply #67 on: August 26 2012, 08:52:28 PM »
As David suggested,  check the torque converter bolts to be sure they are tight.   Sometimes when the flex plate cracks, it makes noises like a concrete mixer but the cracks can be difficult to see you without removing the converter.
Stethoscope can help
Offline gordyzx9r
« Reply #68 on: August 26 2012, 10:01:11 PM »
Alright...so, how do I do that?  Is there a way to rotate that flex plate without taking off my hand?  Could it be the converter?  Is that something I could take off and run to a transmission shop to have them look at?
« Reply #69 on: August 26 2012, 10:14:38 PM »
Take the inspection cover off, bump the starter as needed so you can see each of the three bolts holding the torque converter to the flex plate...put a wrench on each bolt and make sure it is tight....
Don't you live across the lake from NO?  You need to call Clay up and beg for help.  If you feed him well, and he has some spare time, I bet he would give you a hand....
« Reply #70 on: August 27 2012, 02:53:24 AM »
Is it just me, or am I seeing witness marks on the rockers from the adjustable pushrod's nuts?
Try and wipe off as much of that moly from the head nuts too. That stuff will clog oil filters.
After I built my 4.1 I popped the pan to do an inspection and there was a think layer of that goop in my oil pan!
« Last Edit: August 27 2012, 02:57:37 AM by earlbrown »
« Reply #71 on: August 27 2012, 08:45:46 AM »
I see it on two of them but not the others? First 2 pics shows it.
« Reply #72 on: August 27 2012, 09:38:04 AM »
Damn, you have good eyes!  I saw the gouges but I never saw the adjustable nuts...I will plead that I never saw anyone use adjustable push rods for anything other than checking length :D
Offline gordyzx9r
« Reply #73 on: August 27 2012, 11:23:21 AM »
 Nope, I'm still in Southeast Alabama near Dothan...but I trave to NOLA frequently.
I questioned that too when Bill did it, but he said that's what he uses in all his motors.
« Reply #74 on: August 27 2012, 11:25:56 AM »
to each his own :)  I prefer the lighter weight...and I am biased by an Olds engine I had in a '49 Ford that had adjustable rods...and one kept unscrewing and shooting fire out the rear carb
