Author Topic: Best fuel pressure regulator for a modified 87 GN  (Read 9200 times)
Offline Buicksrus
  • Newbie
« on: July 19 2012, 01:49:39 AM »
I have a 1987 GN that has a ACCUFAB fuel pressure regulator, that although rebuilt, does not increase fuel pressure when accelreating.  What FP regulator should I buy to replace the one on my car?
Thanks guys!!!!!!!!!!
Re: Best fuel pressure regulator for a modified 87 GN
« Reply #1 on: July 19 2012, 08:12:33 AM »
Does the pressure change when you remove and replace the vacuum hose?
If so I'd be looking at the pump and filter first.
« Reply #2 on: July 19 2012, 09:46:37 AM »
If it really is the regulator, the one you have is as good as it gets and it can be rebuilt/repaired
« Reply #3 on: July 19 2012, 10:08:56 AM »
Undo the 6 allen head screws & take a look at the diaphram. If it isn't torn then it's probably fine. Thats all they include in a rebuild kit. Pretty unusual for them to tear as they are quite strong.
Offline Scott87
  • Boost Tube
Re: Re: Best fuel pressure regulator for a modified 87 GN
« Reply #4 on: July 19 2012, 10:39:36 AM »
Dumb question but if the diaphragm was torn then wouldn't fuel leak from the vacuum fitting on the regulator?
Posted From Tapatalk
« Reply #5 on: July 19 2012, 02:21:15 PM »
No. The fuel bypassing the diaphragm would be drawn into the engine causing a rich condition. You would notice the issue if you pulled the vacuum line off while the fuel pump was running.
Been there, done that.
Offline Scott87
  • Boost Tube
« Reply #6 on: July 19 2012, 04:06:46 PM »
Good to know, thank you for clarifying :-)
