Author Topic: 2004 Yukon Denali??  (Read 15451 times)
2004 Yukon Denali??
« on: May 16 2012, 11:49:55 AM »
Anyone happen to know where the Front Compartment Heat-AC Blower Motor is located??
There is a Front & a rear but I just need the Front.
Mine is acting up but all I can tell from the engine compartment is that it's somewhere on the Passenger side? I don't see it but I can hear it??
Re: 2004 Yukon Denali??
« Reply #1 on: May 16 2012, 01:00:24 PM »
Mine's at my wifes work.
« Reply #2 on: May 16 2012, 01:10:20 PM »
Just wanted to entertain you while I look it up on Alldata, which verified what I thought. Remove the right side hush and it's behind the glove box. Gives .6 to change it. I hate working on my wife's car so let me know how it works out. :atbeer: :atbeer:
« Reply #3 on: May 16 2012, 04:14:34 PM »
Thanks! I'll pass it onto my mechanic because I don't really want to get into it. I also read on Rock auto the resistor behind glove box can go bad. i have no idea how to test it? Either way i see a $200 penalty shot coming my way with parts & labour.
Motor is $75ish & Resistor is $40ish so one of them needs to be fixed.
Weird that it acted up a few months back but has been fine since. It was Pouring Rain today on the Hiway so maybe the water is partly causing it?
« Reply #4 on: May 17 2012, 05:09:12 PM »
OK here we go again. I seem to remember the last time this happened it was also a Thunderstorm. It POURED for 20 mins while I was on the hiway. Anyways today it's all fine again? I did some reading from Rock Auto & the Ground must be Good. They have had many units sent back to find after testing it was the Ground wire.
You mentioned Hush Panel which I ASSume is the same as kick panel for our ECM? The ground from there must go to a body part or frame?? Any idea where I should look? My buddy wants to wrench on something & other than my PTE stock location intercooler that rattles when the AC is on so I figure maybe we can take a peek while the tools are out. Any ideas are much appreciatted!!
The Beer is on me if I see you at BPG! Just remind me IOU some Cold Ones!!  :atbeer: :atbeer: :atbeer:
« Reply #5 on: May 17 2012, 05:36:27 PM »
You're not too specific on what it's doing. Does it not work on all speeds, just high...
« Reply #6 on: May 17 2012, 05:51:56 PM »
Kick panel is on the side, the hush panel bolts to the underdash
« Reply #7 on: May 17 2012, 06:24:52 PM »
It works like it's blowing about 10% then maybe 50% yet the control is on full. If I set to med or low setting same thing. This was right after the heavy rain & it was on HI yet blew 10% As the day went on it felt like maybe 40%-50% then today it's blowing 100%? When at 10% I could hear the blower motor kick in for a second then out again. Real similar to the Buick AC until I changed the cycling switch.It was trying to work but I figured the motor was dying? I guess that the connection got bad when wet??
« Reply #8 on: May 17 2012, 06:35:17 PM »
The resistor has a higher failure rate than the motor.
« Last Edit: May 17 2012, 07:06:43 PM by Pyro6 »
« Reply #9 on: May 17 2012, 07:36:45 PM »
Thanks! I was reading about them as well at Rock Auto link they have.
