Author Topic: Brake lines  (Read 7684 times)
Brake lines
« on: March 16 2012, 07:59:38 PM »
found on a Ford forum :)
Question:
What precentage of independent auto repair shops will repair rotted out rear brake lines by cutting
 out the bad part and connecting a new line to it instead of bending a new line completely from end to end?
Answer:
Probably one that doesn't carry any insurance or bonded.
Re: Brake lines
« Reply #1 on: March 16 2012, 08:17:32 PM »
Question:
Answer:
I have fixed a number of those supposed fixes. :(
AJ___
Re: Brake lines
« Reply #2 on: March 16 2012, 08:46:52 PM »
Done it myself because customer is to cheap to replace the whole line. :013:
Re: Brake lines
« Reply #3 on: March 16 2012, 11:20:55 PM »
Trying to understand that how is it cheaper to use two couplers and 4 fittings than 2 fittings and one chunk of line?
AJ___
Re: Brake lines
« Reply #4 on: March 16 2012, 11:30:47 PM »
Tho finding the oversize fittings at the master cyl  can be a bit of a chore.
Re: Brake lines
« Reply #5 on: March 17 2012, 12:25:26 AM »
AJ___
Depends on the location and legnth AJ. I had one here just after Christmas late one night with a couple of guys driving to Mexico. To do it right the bed would have to be removed and the cab lifted. Just cuting the bad pipe out and patching it took 3 hours in the rain using a flashlight. :013:  Total PITA but it paid $300 labor with the late night ect. :rock:
Re: Brake lines
« Reply #6 on: March 17 2012, 12:41:38 AM »
Canadian Tire has 'em. Been making up our own line locks with 'em.
Re: Brake lines
« Reply #7 on: March 17 2012, 07:12:45 AM »
I not saying I did not try it, but after cutting the tubing 3 or 4 times and having bad flares because the difference in metal thickness I did not bother again. And it was one like you are talking about Charlie middle night raining cold wind etc.
AJ___
