Author Topic: Camshaft/timing chain  (Read 11724 times)
« on: December 10 2011, 06:43:08 PM »
Installed the camshaft today - burnished and brushed it with copious amounts of Moroso gray moly assy lube. Cam slipped right in - but the #3 cam journal seemed much tighter that #1 and #1. I hope it's OK. I can still turn the camshaft with relative ease.
I installed the Rollmaster chain too - seems s bit snug, but it went on without any persuasion by hammer. :P
Does this look like acceptable deflection? I measured it as 1/10" or 2-3mm.
« Last Edit: December 11 2011, 11:32:58 AM by SuperSix »
Re: Camshaft/timing chain
« Reply #1 on: December 10 2011, 09:14:33 PM »
Should be good Mark.
« Reply #2 on: December 11 2011, 10:43:50 AM »
The snug fit on cam journal #3 concerns me. I eventually got it past the journal, but it took a bit of time and wiggling. Now I want to pull the cam and measure. Dammit.
« Reply #3 on: December 11 2011, 01:22:24 PM »
Look on the inside of your timing cover...   on the boss the cam sensor pokes though is a boss of aluminum of unknown use.
The rollmasters are known to hit that flap of metal. A die grinder with a reinforced cutoff wheel will make quicker work of removing it (but smaller chips). a normal doublecut carbide burr will knock it down as well.
« Reply #4 on: December 11 2011, 10:13:16 PM »
if the cam turns freely, find something else to worry about
« Reply #5 on: December 12 2011, 10:19:40 AM »
Good to know - I saw that mentioned somewhere - but didn't know that it affected the Rollmaster units.
ok - thanks, I needed that. :P
