Author Topic: AC Compressor Switch  (Read 16695 times)
« on: September 05 2011, 12:01:08 PM »
I'm looking for help finding a part number or a link to who sells the Red Plug 2 wire compressor switch that plugs in on top of the 87 AC compressor. Plug is here but where do I find the switch?
Thanks!! http://www.casperselectronics.com/store2/product_info.php?cPath=5_6_9&products_id=1013
Re: AC Compressor Switch
« Reply #1 on: September 05 2011, 12:55:00 PM »
this one?
« Reply #2 on: September 05 2011, 01:43:10 PM »
Hard to tell from that pic?? I thought they were more oval? I also thought you could just unscrew them?
« Last Edit: September 05 2011, 01:54:17 PM by SuperSix »
« Reply #4 on: September 05 2011, 01:49:49 PM »
four seasons-  35961 ?
« Reply #7 on: September 05 2011, 02:01:57 PM »
Press fit into an O-ring then retained by a C-clip, the small drill bit to pry against was the only way to get that one out without destruction.
« Reply #9 on: September 05 2011, 03:36:45 PM »
I take the snap ring out and then use the snap ring pliers around it and pry up. Work slowly and you can get it out without breaking it.
« Reply #10 on: September 05 2011, 03:51:05 PM »
http://www.nos4gn.com/servlet/the-625/Buick-Grand-National-AC/Detail
http://www.rockauto.com/dbphp/prt,315,1550812
Is yours defective? Why do you want to replace it?
Mine works fine but I have to crazy glue it in place to keep a good connection. I tried a new Caspers plug & same thing. Someday when I drain the system for the new polished accumulator I'd like to add the new switch. Altho, the crazy glue works not bad.
« Reply #11 on: September 05 2011, 04:31:58 PM »
Probably did what I did on the first one, by the time it was out- the tab that locks the plug on was destroyed. One of the AC guys mentioned he only manages to save half of them.
Charlie haz skilz  :)
