Author Topic: puffs of black smoke??  (Read 11616 times)
« on: August 15 2011, 12:37:37 PM »
Was following the buick to a car show this weekend, noticed something and have a stupid question. When she would accelerate from a stop using maybe 10 lbs. of boost the car would puff a small amount of black smoke at each shift. Bad thing or normal?? Also when she lifts on the gas it puffs a bit of blue smoke, I knew it was burning a small amount of oil, maybe 3/4 quart in 3000 miles, so I figure that was that issue.
Re: puffs of black smoke??
« Reply #1 on: August 15 2011, 01:12:19 PM »
Two different issues. Black usually indicates a rich condition, blue is oil.
« Reply #2 on: August 15 2011, 08:42:37 PM »
You have one of Erics chips in your car...and he errs on the rich side on his default settings...so it may be normal.
« Reply #3 on: August 15 2011, 10:39:28 PM »
watch the 02s when you lift off the gas and then see what happens after the initial lift
« Reply #4 on: August 15 2011, 10:48:01 PM »
on a WOT run its between 800 and 810 (lowest recorded reading). I'll  watch see what it reads just after I lift.
« Reply #5 on: August 15 2011, 11:42:55 PM »
running pretty rich to begin with
« Reply #6 on: August 16 2011, 08:42:15 AM »
I am still on the default settings, I'll take some fuel out and see what happens. I had so much knock trouble before that I'm probably overcautious.
Thanks!
« Reply #7 on: August 16 2011, 09:03:01 AM »
the cautious run longer
« Reply #8 on: August 16 2011, 09:24:33 AM »
but run slower
« Reply #9 on: August 16 2011, 10:34:10 AM »
yep
