Author Topic: Put on Roberts (Be4u) IC  (Read 7661 times)
Offline Ttype83
« on: March 05 2008, 06:11:02 PM »
I still need to slot the bolt holes on the passenger side for more clearance, but I hammer gave me enough ( 1/4" ) so good enough for now. I used the stock shroud for now, but Earl has me talked into trying to make one from fiberglass. I started making my templates, but need to get something stronger than cardboard for the sides.
I still need to take it for a test run as well
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline 87natty
« Reply #1 on: March 05 2008, 06:58:36 PM »
Jim! Sheet metal and a brake! shouldn't be too hard, make a cardboard templates and bend a couple 90's. Then rivet it up!
Offline Ttype83
« Reply #2 on: March 05 2008, 07:09:20 PM »
Quote from: "87natty @ Wed Mar 05, 2008 6:58 pm"
I've worked with sheet metal before, but thought earl had a good idea..it would be different.
CarbedHotAir Slug
Offline Recklessrob
Re: Put on Roberts (Be4u) IC
« Reply #3 on: March 05 2008, 07:51:41 PM »
Ypu should be able to get some coated aluminum from Home Depot for the sides
of your mold. Spray Pam on it before you lay the fiberglass to keep it from sticking.
This method works the balls.
Rob
DCEPTCN
  • Guest
« Reply #4 on: March 05 2008, 07:53:17 PM »
Oh Jesus, I'm sorry Jim- I forgot all about sending you that shroud...I'm not home for a few weeks, but I promise I *will* get it to ya.
Offline Ttype83
« Reply #5 on: March 05 2008, 07:58:29 PM »
Quote from: "Recklessrob @ Wed Mar 05, 2008 7:51 pm"
Earl told me about that...hmmm I wonder what he's been doing with pam ..
I'll make the template then spray the inside with foam, the foam will became my mold
for the fiberglass.
Quote from: "DCEPTCN @ Wed Mar 05, 2008 7:53 pm"
No biggie, I had forgot about you having it...darn age thing.
CarbedHotAir Slug
