Author Topic: TR6 problems  (Read 24258 times)
Re: TR6 problems
« Reply #15 on: August 27 2018, 08:13:50 AM »
Is there another type of coil being used as well?  Somewhere in the back of my mind, I keep thinking I have heard of a problem with the LS coils....but it rained here and my imagination is fertile.
IGN1A is the preferred coil but somewhat pricey
Re: TR6 problems
« Reply #16 on: August 27 2018, 11:01:05 AM »
So who makes  real 1A coils? Looks like they originated from Mercury Marine?
Re: TR6 problems
« Reply #17 on: August 27 2018, 01:49:20 PM »
I think the Mercury Marine are the real ones...and then there are the clones...I'm thinking this is an awfully expensive way to go if you are making less than 700 hp
Re: TR6 problems
« Reply #18 on: August 27 2018, 10:46:59 PM »
I'll continue to use the LS coils
TR6 problems
« Reply #19 on: August 28 2018, 12:08:49 PM »
Delco coils Jason?
The ING require a different harness correct?
Re: TR6 problems
« Reply #20 on: August 28 2018, 09:40:09 PM »
Delco coils Jason?
Yes sir. Delco coils. As far as I know and I could be wrong there is no need to change the harness for the IGN1A coils
Re: TR6 problems
« Reply #21 on: August 30 2018, 03:40:06 PM »
well its back... what ever my problem is its not my ground or module I have a stock known good in it now. I checked the fuel pressure it seems good rises with boost, the symptoms pointed to ignition if I launch it hard once I get to about 4000 rpm 19, 20 psi it falls flat. All the intercooler hoses are tight and it drives great under normal driving conditions no codes and my logs look fine no knock fueling is good. I'm gonna swap out the crank sensor see if its giving me grief and make sure the balancer is tight.
any other suggestions?
Re: TR6 problems
« Reply #22 on: August 30 2018, 05:49:46 PM »
broken valve spring?
Re: TR6 problems
« Reply #23 on: August 30 2018, 08:19:55 PM »
Are you blowing out the spark?
TR6 problems
« Reply #24 on: August 30 2018, 09:58:48 PM »
Well it’s not the crank sensor.
I’m gonna pull all the plugs and check them and give it a compression test.
The valve train sounds fine the spring where new this winter Comp 941
It’s like it hits a rev limiter at 4000 rpm I stayed into it a bit just started to lose steam. Hitting on 4 out of 6 holes.
Re: TR6 problems
« Reply #25 on: August 30 2018, 10:45:16 PM »
Ohm out the wires while you're checking stuff
Re: TR6 problems
« Reply #26 on: August 30 2018, 10:57:47 PM »
did you send it into Bob?
TR6 problems
« Reply #27 on: August 30 2018, 11:25:58 PM »
Bob has the TR6 I have borrowed a known good stock set up.
TR6 problems
« Reply #28 on: August 31 2018, 05:52:15 PM »
Ok so compression is with in 5lbs around 130  plugs all look good
Re: TR6 problems
« Reply #29 on: August 31 2018, 05:57:43 PM »
What's your voltage?
