Author Topic: Precision Turbo Longevity  (Read 33410 times)
Re: Precision Turbo Longevity
« Reply #15 on: April 30 2018, 10:31:19 AM »
OK, I'm seeing $130 turbos on the bay. Are there compressor maps for this stuff?
It would be quite funny to take a far east intercooler and turbo and be competitive in our elitist circles.
No, they are known-unknowns - but you can estimate the performance based upon known-knowns of like turbos.  I'd argue that a bit too much thought is put into things sometimes... just accepting that it works in an acceptable range is good enough.  It isn't an F1 motor.
I have a Chineseium (bottom mounted and scooped) intercooler on my TBSS and it is making 650+hp and has incredibly low IATs (at 12psi).  I had a modified FMIC from an International semi on my Buick and it worked great at 30psi (it had better hold given the original application) and always had great IATs too.  Cost effective options work.
The quality gap has closed and many of our speed parts are coming from off-shore locations... I'd like to continue to build fun cars AND put my girls through baseball, soccer, swimming, horseback riding, university, marriage too; and if it means a few "corners" are cut so be it.
I cannot wait to pull the compressor housing off and paint it lavender like the valve covers... and maybe put some My Little Pony stickers under the clearcoat too.  Just to further fuck with people's egos.
« Reply #16 on: April 30 2018, 12:03:12 PM »
Cough, cough start looking at gt3582 turbos on eBay - you have to watch the specs as they vary but most of them are 62/62. They come in many flavors and results may vary. It’d be awesome to have the resources to do some independent testing.
« Reply #17 on: April 30 2018, 12:22:04 PM »
https://www.ebay.com/itm/T3-GT3582-GT35-BALL-BEARING-Turbo-charger-Anti-Surge/112259795170?hash=item1a233488e2:g:7I8AAOSwARZXn5~1&vxp=mtr
Yup, I am considering one of these for Natasha's Colorado.  Folks are using them as twins for cheap on junkyard V8s.
« Reply #18 on: April 30 2018, 03:54:22 PM »
That's the thing about Chinese parts. They aren't automatically 100% garbage.   If you give them a good print and a good materials list, they can make parts just as good as anybody can.  THe trick is figure out which one you have at the time.
It's actually kinda funny how we see ''Made In China'' and think garbage, but on their end, they're creating a 'brand name' (wiht price) for the entire country.
  Basically they feel like they're where Japan was in the 70's.   Back when ''Made in Japan'' on electronics were crap.  Boy have times changed there.
« Reply #19 on: April 30 2018, 10:17:41 PM »
William Edwards Deming, an engineer from Iowa helped post war Japan develop a systematic improvement in quality- an interesting read.
« Reply #20 on: April 30 2018, 10:46:25 PM »
I attended a seminar by him around 1989
« Reply #21 on: May 01 2018, 09:09:47 AM »
I attended Disney World around 1989.
« Reply #22 on: May 01 2018, 11:31:30 AM »
So did I- with my 5yr old.  :hmm
« Reply #23 on: May 02 2018, 01:03:45 AM »
I got arrested for possession of alcohol by a minor in 1989.
« Reply #24 on: May 02 2018, 01:55:53 PM »
I'm sure there was nothing minor about your behaviour at that point
« Reply #25 on: May 02 2018, 04:36:35 PM »
Earl i did that in 79 lol
« Last Edit: May 02 2018, 05:50:05 PM by larrym »
« Reply #26 on: May 02 2018, 09:54:54 PM »
I believe there's a girl named Melissa will never forget me from 1989
« Reply #27 on: May 02 2018, 10:32:21 PM »
FTFY. ;)
« Reply #28 on: May 02 2018, 10:45:22 PM »
*like*
« Reply #29 on: May 03 2018, 02:22:45 PM »
FTFY. ;)
That's not illegal. Age of Consent in GA is 16.
Giggidy  :tongue
