Author Topic: 2016 Ford vs Buick  (Read 13821 times)
Re: 2016 Ford vs Buick
« Reply #30 on: October 16 2016, 02:34:59 PM »
It looks pretty good when you use the right rpm!
« Last Edit: October 16 2016, 03:34:04 PM by Steve Wood »
« Reply #31 on: October 16 2016, 02:38:47 PM »
Steve I ran the numbers on the Wallace calculator and came up with 5.916%. Am I doing something wrong?  Tire circumference is 87.8
Offline gusszgs
  • Limited quick brick
« Reply #32 on: October 16 2016, 03:09:08 PM »
I got 6.5% on the TCI calculator
« Last Edit: October 16 2016, 03:13:29 PM by gusszgs »
Jim
1987 T Limited
« Reply #33 on: October 16 2016, 03:27:31 PM »
Wallace says 28" tire, 1.0 tranny gear, 3.42 rear gear is 146.14 mph at 6000 rpm.  What percentage is that compared to 116.5 ?
I round off to 80%
LOL...OOPS! I need to clean my glasses!
your number is right...pretty good!
« Last Edit: October 16 2016, 03:34:33 PM by Steve Wood »
« Reply #34 on: October 16 2016, 03:39:34 PM »
You may need a looser converter for best times as it must be starting out in third around 4300 rpm?  With your cam and turbo, it will probably go faster if it drops to about 5200, I think
« Reply #35 on: October 16 2016, 04:26:34 PM »
That 60' needs some work.
« Reply #36 on: October 16 2016, 09:38:26 PM »
Here's a link to the video. Thanks to Steve Botkol for sharing it.
https://www.facebook.com/jason.goodwin.5076/posts/10209112830795846
« Reply #37 on: October 17 2016, 11:46:06 PM »
Found out why I wasn't spraying alky.... After changing the engine harness, I didn't completely seat the connector to the MAP sensor.  It's spraying now.
Also, installed a standard waste gate actuator after locating it on the bracket and then welded it up. I didn't make any test hits. Too much stuff to do....
