Author Topic: Roller cam options  (Read 28812 times)
Re: Roller cam options
« Reply #15 on: May 03 2016, 02:10:58 PM »
« Reply #16 on: May 03 2016, 04:26:44 PM »
Now isn't that a cute little baby roller cam.....
That is a little one!
Roller cam options
« Reply #17 on: May 04 2016, 10:37:14 AM »
I found it interesting after the discussion on how much lift could be used on untouched heads that these would be introduced.
« Reply #18 on: May 04 2016, 01:33:38 PM »
I looked up the stock cam specs to compare to the new full throttle stock replacement roller cam  Here we go:
Stock cam:        Duration @ .050                        Lift at .050
                         intake        192                         intake    .384
                         exhaust      196                        exhaust  .408
                         lobe separation is 107 and overlap is 38
Roller 204:         intake        204                         intake    .440
                         exhaust      204                        exhaust  .440
                         lobe separation is 111 and could not find overlap
« Reply #19 on: May 04 2016, 02:41:16 PM »
for a baby roller its still a good step up from stock nice post Jason
« Reply #20 on: May 05 2016, 12:10:27 PM »
So are you going to be putting the Fetis cam in?
