Author Topic: nocooler's firechicken thread  (Read 914707 times)
0 Members and 14 Guests are viewing this topic.
« Reply #330 on: June 02 2017, 02:29:17 PM »
We will have to compare SD tuning notes. Are you doing OLSD or CLSD?
Also, toss the 80s in and start tuning it in ASAP - it'll save you some ass pain down the line from idle to 100kpa.  Do you have the injector data for them, if not I should (because I am using them in the Monte's 4.8L).
« Reply #331 on: June 02 2017, 03:38:58 PM »
Its olsd right now - after I'm happy with it, I'll try closed loop.
The plan was to get the 36s tuned and then swap over to the 80s. Im pretty sure I have data for them, gotta review some emails and threads.
« Reply #332 on: June 03 2017, 03:46:28 PM »
Went to a car show just to hang out and got asked to participate. I came home with a plaque- and I didn't even dust the car off.
« Reply #333 on: June 03 2017, 04:20:51 PM »
HPTuners VE Tuning 101 - verify that your maf failed. Mine wasn't I had a nice VE table but I was hitting 100% way to early and going 120%+
MAF codes were set to fail on 2nd error, not 1st. Now It's rich - time to start over
« Reply #334 on: June 04 2017, 08:21:18 PM »
I "trick" I have learned of is to zero out the entire MAF scale less the first cell.  In the first cell you put a number 5-18 g/s seems to be the going rate, so it has something to detect against as a failure.  This helps to ensure the MAF fails.
« Reply #335 on: June 04 2017, 08:48:32 PM »
Cool - I'll add it to the list. Thanks
« Reply #336 on: June 05 2017, 09:10:15 AM »
https://ls1tech.com/forums/pcm-diagnostics-tuning/1830132-injector-data-sticky.html
Here is the data for the Deka 80s.  Cannot believe I didn't see this sticky before today?
« Reply #337 on: June 05 2017, 09:29:15 AM »
Thanks Mike - I had that bookmarked but it wasn't stuck yet.
« Reply #340 on: June 06 2017, 11:19:53 AM »
Segment swapping (ie. changing from a 4L60E to 4L80e) looks like it is just done with a drop down menu now.  I only got a few minutes to review the changes last night, but there is a lot of new parameters showing in the 0411 PCM now.
I would KILL for the guys at HP Tuners to start writing unique OSs for stand alone functionality that had WB integration for CL feedback - especially under PE/load.
« Reply #341 on: June 06 2017, 12:20:43 PM »
Mike, I've tried the drop down and it did not work - I had to send a file in to be swapped. Closed loop would be cool, I'd really like a flex fuel custom os for the 411 pcm. Yes I know I can flash a Truck OS to the pcm, but that causes issues with licensing and cost credits.
Dave - yup we can void your warranty :D
« Reply #342 on: June 06 2017, 03:48:21 PM »
[quote author=nocooler
That is the only thing stopping me from loading up forscan and enabling a whack of options :)
« Reply #343 on: June 06 2017, 06:50:56 PM »
Forscan looks cool - they really don't say much about what it'll do but it does look like you can make some nice changes. It'd be fun to test drive one, make some changes and return it
« Reply #344 on: June 07 2017, 02:14:14 PM »
Fuck me this thing is even more stupid. I've got the VE table just about done. Right now it's a car you have to drive. It's going to be down right scary with a turbo.
