Author Topic: nocooler's firechicken thread  (Read 914706 times)
0 Members and 14 Guests are viewing this topic.
« Reply #1350 on: August 15 2022, 12:33:10 PM »
We had a bunch of worn out holes in the 440 heads (header holes).  We used Timeserts because I had heard they were much better than other options.  They took a lot of work compared to helicoils and we used blue loctite on them because some go into the water jackets.
Recently, I saw one of the youtube channels testing them vs other threaded fasteners and they did not do as well as the old helicoil when it came to strength.  I guarantee the helicoils are faster, easier, and a lot cheaper.
I think I would use some loctite and install them to stay LOL
https://www.youtube.com/watch?v=NZItuPnU7lU
Cheap is the way to go as long as it is an insert
and my favorite channel because I cannot figure out how he talks so fast without missing a beat.  https://www.youtube.com/watch?v=jknMrFOGMOQ
« Last Edit: August 15 2022, 12:56:12 PM by Steve Wood »
« Reply #1351 on: August 15 2022, 02:51:08 PM »
I went with a helicoil - I needed up repairing both bottom holes
I'm gonna let the thread locker setup and put it back together tomorrow
« Reply #1352 on: August 15 2022, 06:27:16 PM »
Should be better than new and the price is not too bad
« Reply #1353 on: August 17 2022, 08:48:02 PM »
Whiskey tango foxtrot….
Got it all buttoned up and nothing - no fluid flow. I ran it through all the gears, had the dipstick out of the tube and after I shut it down it volcano’d fluid out of the dipstick tube and made a mess.
Who knows what I messed up - sigh
« Reply #1354 on: August 17 2022, 09:08:59 PM »
does it have a breather that may have become stuck closed?
« Reply #1355 on: August 17 2022, 09:17:45 PM »
I did not think of that Steve.
It’s got a puke tank setup and I did tighten the fitting in the case. I wonder if the way it’s drilled and tapped it intersects the hole and running it in tighter may have blocked it?
« Reply #1356 on: August 17 2022, 10:09:39 PM »
Worth looking into if there is no other idea
« Reply #1357 on: August 18 2022, 01:54:23 PM »
After removing the vent fitting it builds some pressure but it’s way down, won’t engage and sounds like and air compressor when you shut it down.
I guess I get to tear it back apart. I’m guessing the gasket for the pump moved or I really messed something up.
What are the chances I knocked the filter loose messing with it? I guess dropping the pan is easier than the transmission.
« Reply #1358 on: August 18 2022, 02:17:31 PM »
I would guess not much chance on the filter, but, might as well start with the easy and hope!  I have seen stranger, less likely...
« Reply #1359 on: August 18 2022, 04:22:06 PM »
I'm not thinking it's likely, I find it odd that the damn thing is still leaking - so the paper gaskets probably moved on me when I put the pump in.
« Reply #1360 on: August 18 2022, 07:18:48 PM »
https://shop.ukrtrans.biz/wp-content/uploads/catalogs/TH400.pdf
This saved me $40, I’m thinking I’m gonna need it
« Reply #1361 on: August 18 2022, 07:20:22 PM »
Any sign of warpage. Wondering if those holes were stripped by someone trying to stop it from leaking
« Reply #1362 on: August 19 2022, 02:35:43 PM »
Paper gasket was out of place, on the pump inlet....yeah that'll do it.
« Reply #1363 on: August 19 2022, 02:58:02 PM »
That's good news. Hopefully no more on leaks!
« Reply #1364 on: August 23 2022, 01:53:57 PM »
Well, it's back in and works, but it still fucking leaks.
From what I could see everything is flat.
Where it's leaking it could only come from the pump, fluid sits on top of the pan rail directly under the pump - I'm not seeing how it could come from anyone else as it'd have to flow up hill.
It doesn't leak when it's running only when it sits - I need a break from this damn thing.
