Welcome to IHADAV8.com!
alky is awesome
Pages:
2
Topic: alky is awesome (Read 18275 times)
Shimy87
PSI: 2
Re: alky is awesome
Reply #15 on:
July 23 2013, 06:20:51 PM »
Yes both sides, same hop
PacecarTA
Turbo Street Limited
PSI: 2
im not a newbie
Re: alky is awesome
Reply #16 on:
July 23 2013, 06:28:01 PM »
sig says bushings
are your lower arms stock?
did you do bushings in axle ears
sig says helwig which means the stock bar is no longer on the arms
if you have stock did you replace the swaybar bolts (and inner support) or box the lowers ?
Paul Magnabuick.com ..NJ rep
86GN pump gas 93/alky 109, iron heads, stock mains, no girdle 9.72 @139
87 GnX'd
87 GN TTop..stock as can b
Shimy87
PSI: 2
Re: alky is awesome
Reply #17 on:
July 23 2013, 07:08:51 PM »
Stock arms, boxed. Helwig sway bar with hardware they supplied. Energy suspension poly bushings in lower arms stock bushings in upper arms
Pages:
2
alky is awesome
