Author Topic: Heads with modified stems, ok for stock rocker shaft use?  (Read 24571 times)
Re: Heads with modified stems, ok for stock rocker shaft use?
« Reply #15 on: September 10 2011, 09:35:04 PM »
Got some more info - 380.00 + 70.00 shipping..
" I mildly ported the runners.   I did not port the bowls. "
See anything I should be alarmed about?
« Reply #16 on: September 10 2011, 10:14:25 PM »
A little rough but you can clean them up easily Mark. If you want the bigger valves ect then I'd say go for it.
« Reply #17 on: September 11 2011, 12:13:50 AM »
As I said, I would do it
