Author Topic: how to re-install steering shaft boot clamp?  (Read 28182 times)
Offline 1KWIKSIX
Re: how to re-install steering shaft boot clamp?
« Reply #15 on: September 11 2011, 08:34:50 PM »
Did you have to grind bolt clearance as some claim?
Nope, no grinding req'd. The top bolt threaded itself in all by itself (will need the help of a ratched & socket though as it will be cutting some threads as it goes in for the first time), no need to grind the steering shaft it connects to.
It is a simple straightforwar d bolt on......gonna keep mine for potential future installation.
Sent you a PM.
dave
« Reply #16 on: September 12 2011, 07:11:00 AM »
Sent you a PM.
dave
Pretty much the same story here. I just cleaned up the column shaft with a file and sandpaper before installing. That and I had to spread open up the steering shaft collars with a hammer and screwdriver.
