Zap *STILL* wears Depends
A/C, Heating and Cooling
hot cold blend door
Topic: hot cold blend door (Read 3591 times)
Shimy87
PSI: 2
hot cold blend door
May 04 2021, 11:50:15 AM »
Well this weekend slid the hot/cold lever over to hot. later go to slid it back to cold and feel some resistance then it slides to cold but no cold air
looks like the cable connects to a v shaped plastic arm that moves the door. Well the plastic V broke where the cable connects. It also appears you need to remove the entire dash to replace that part
Anyone run into this dilema?
Re: hot cold blend door
May 04 2021, 01:14:33 PM »
this arm?
https://vortexbuicks-etc.com/heater_cable.htm
Shimy87
PSI: 2
May 04 2021, 03:02:20 PM »
Hey Steve, yup thats the culprit. I did some research and found the part on a vendor site. Thanks for the info!!
May 04 2021, 03:43:42 PM »
lucky that one is an easy fix
May 06 2021, 09:09:53 PM »
was a much harder fix before the parts became available
May 06 2021, 09:45:48 PM »
don't you have a 3d printer?
May 12 2021, 08:09:04 PM »
Quote from: Steve Wood
Didn't back then.PLA is not that strong.Would have to beef it up. Sending it out is actually fairly cheap tho
Just a Six?
OK Now who Farted??
PSI: 2
May 16 2021, 03:29:58 PM »
Mine went many years ago & I drilled it out a bit & used a nut & bolt that's still working fine. Altho having the right part is always nice.
David
87 LTD. Purchased May 88
Doeskin leather, coach lites without Landau Roof, moon roof, carpeted trunk & No Factory Hood Ornament!
The sticker on AC shows a V-8 Carb car. Special order by Mr. Nick Hall VP of GM Canada
Runs 11.50 on 21 lbs with my old style 67 Q Trim & Alchy
hot cold blend door
