Author Topic: Cracked Header!!!  (Read 9062 times)
Offline kma697
Cracked Header!!!
« on: October 08 2006, 05:21:21 PM »
What problems are caused by a cracked header??  I am obviously a noobie but was curious cause I saw a post where someone parked the car until the header was replaced, is it that serious??  Any help is appreciated :newbucket1: .
DSR #420
89 TTA #602
89 Mustang LX 5.0 Vert.
03 Cobra
Cracked Header!!!
« Reply #1 on: October 08 2006, 07:01:40 PM »
Unless it is really bad, you can drive it.  Max performance and turbo spool up speed maybe affected.  If you have a scanmaster you can check your BL's to see if they are within their control range (90-150).  Ideally they should be in the middle like around 128.
DCEPTCN
  • Guest
Re: Cracked Header!!!
« Reply #2 on: October 08 2006, 07:57:25 PM »
Lesser performance and that embarrassing 'ticking' sound. No fun. I've got an ATR replacement on the driver's side and I'd reccommend them if they weren't out of business.
Offline Be4u
Cracked Header!!!
« Reply #3 on: October 08 2006, 08:19:51 PM »
I drove my car with a leak. I know it messes with your o2 counts...makes them read low and adds fuel which makes your oil smell like gas or something.
Save the bumper fillers!
Move to Canadia!
« Reply #4 on: October 08 2006, 11:22:15 PM »
Fixing my cracked header made a WORLD of difference on bith TR's that I have owned - the tough part is finding someone good to weld them. It's thin, cheap stainless, so they have to have a steady hand so to get a good seal, and not burn through the material.
Get is fixed, NOW, you can;t tune the car correctly w/cracked header(s).
(Check your passenger side too!)
And WELCOME to IHADAV8.com!
Offline Recklessrob
« Reply #5 on: October 09 2006, 01:08:52 AM »
Also make sure its the header and not just
a blown out gasket. That happened to me a few months ago.
Welcome to the board.
 :psix;
Rob
Offline ledzeppac
Cracked Header!!!
« Reply #6 on: October 09 2006, 03:15:43 AM »
lickourballs
Offline 87natty
Cracked Header!!!
« Reply #7 on: October 09 2006, 03:58:28 AM »
The gay tourettes strike again.
Offline ledzeppac
Cracked Header!!!
« Reply #8 on: October 09 2006, 01:15:48 PM »
he needs to be broke in sometime....
Offline kma697
« Reply #9 on: October 09 2006, 02:22:48 PM »
Thanks for the tip on the gasket!!  I will get it fixed as soon as possible.  I heard it causes alot of problems dealing with boost and tuning so I guess my buds were correct.  PS Thanks for the kind words guys and glad to be aboard!!! :atbeer:
DSR #420
89 TTA #602
03 Cobra
Offline Recklessrob
« Reply #10 on: October 09 2006, 05:46:21 PM »
Hazings should only take place in the playground or shoutbox. IMHO.
Rob
Cracked Header!!!
« Reply #11 on: October 09 2006, 07:35:16 PM »
Quote from: "ledzeppac @ Mon Oct 09, 2006 2:15 am"
lickourballs
With as few real tech threads we DO get, try to stay out of them unless you have something constuctive (and related to the topic) to say, Phil
In the Off Topic/Playground have all the fun you want. :)
Thanks
