Author Topic: Fuel pump  (Read 10611 times)
Offline wmsonta
  • Turbo Street Stock
  • PSI: -1
Re: Fuel pump
« Reply #15 on: June 26 2019, 06:10:53 PM »
I installed my DW 200 (S), in the oem position. No problem except their strainer would not work. I used the oem style rubber boot on the bottom and clocked the pump for a Napa #B-0052-S strainer. I installed the strainer in parallel w/the float. Possibly, the 300 series would work the same. I did not alter the fuel sending unit in any way.
I will see if the idle problem is going to straighten itself out. It is much better. Too bad I can not drive the car.
