Welcome to IHADAV8.com!
Dan, did you do a run with it not locked up? And if so what was the ET and mph difference?
Ours is a 9/11 LU 9/11 is sitting with an old motor an trans. Her new set up is a stroker with a PTC NL. Still hung up on LU's here unless your trying to get every single 100th out of the car
Quote from: Grumpy on January 20 2018, 01:17:47 PMOurs is a 9/11 LU 9/11 is sitting with an old motor an trans. Her new set up is a stroker with a PTC NL. Still hung up on LU's here unless your trying to get every single 100th out of the car Dan...the reading I've done says you really have to buzz the RPM's to maximize a stroker. Any truth to that with you guys.
Quote from: Scoobum on January 20 2018, 04:32:11 PMQuote from: Grumpy on January 20 2018, 01:17:47 PMOurs is a 9/11 LU 9/11 is sitting with an old motor an trans. Her new set up is a stroker with a PTC NL. Still hung up on LU's here unless your trying to get every single 100th out of the car Dan...the reading I've done says you really have to buzz the RPM's to maximize a stroker. Any truth to that with you guys.The opposite is true. You will make more hp and torque but in a smaller range. A destroked motor won't make as much peak hp and torque but will do it over a bigger rpm range, I believe. Earl? Earl?
But nothing sounds as good as a 327 destroked to 301 with a 283 crank shifting at 8500rpms
