Author Topic: David Suzuki...Lieing POS!!!!!!!!!!!  (Read 10875 times)
« on: June 08 2016, 04:01:12 PM »
Look at this piece of garbage...liei ng and scaring the crap out of school children. Fukn POS!!!!!!!!
https://www.youtube.com/watch?v=dBaGAG5ftYs
Offline gusszgs
  • Limited quick brick
Re: David Suzuki...Lieing POS!!!!!!!!!!!
« Reply #1 on: June 08 2016, 04:27:54 PM »
Yep get into the schools and brainwash em while they're young.
Oh and by the way, can we get E85 in Ontario yet?  :rolleyes;
Jim
1987 T Limited
« Reply #2 on: June 08 2016, 04:43:31 PM »
scaring kids isn't the way to go about educating people about climate change.
« Reply #3 on: June 08 2016, 08:55:53 PM »
Just goes to show, you better have a handle on your children or someone else sure will.
« Reply #4 on: June 08 2016, 11:06:56 PM »
I've got access to it.  Just ordered a 450L/hr pump for the TBSS, going to need some big ass injectors (like 120lb/hr big).
« Reply #5 on: June 09 2016, 09:40:02 PM »
I get a kick out of how we go from some political or socialist BS right back to cars, the way it should be. I think our next president should come from here.
Offline gusszgs
« Reply #6 on: June 10 2016, 09:08:50 AM »
I was kind of sarcastically tying the E85, and being environmentall y friendly together. I mean if the gov't is serious about reducing emmisions, then why have we waited so long for E85?
Jim
1987 T Limited
« Reply #7 on: June 10 2016, 11:10:26 AM »
Because to be a viable economic fuel it must have govt funding and subsidies. And it makes the supply of corn goofy and the need to feed livestock then comes into play.
Offline gusszgs
« Reply #8 on: June 10 2016, 04:21:02 PM »
Yepper, then your price of beef sky rockets....... ..not that it hasn't already
Jim
1987 T Limited
« Reply #9 on: June 10 2016, 05:08:32 PM »
Getting plenty of rain here so hay should be cheap this year. They are already getting the first cutting. Might get four this year.
« Reply #10 on: June 13 2016, 07:11:03 PM »
Actually the grains used to make likker become better feed for livestock.  They're called DDGs for Dried Distillers Grains.   After converting the starch to sugars then removing it, the 'waste product' is a higher protein feed.
The reason Ethanol isn't bigger here is because of the IRS.   Having to dry the living shit out of it so that it can be mixed with gasoline really drives up the cost of distillation and significantly lowers fuel yield (not to mention having to buy, transport and store the gasoline required to poison it)
If you take away the gasoline water could be left in there making a much better fuel (and more of it).   The 'downside' of that being one could drink it without dieing. And there's no tax money in that.
« Last Edit: June 13 2016, 07:20:40 PM by earlbrown »
