Author Topic: Which Belt?  (Read 10975 times)
Which Belt?
« on: May 11 2016, 08:38:47 AM »
GATES K060635
GATES K060640 ?
The Continental (Goodyear) I just put on seems to be utter crap.
Re: Which Belt?
« Reply #1 on: May 11 2016, 08:48:21 AM »
I am pretty sure the 64 is the stock length and the 635 is a half inch shorter.  I have the 64 on my barn motor.
Re: Which Belt?
« Reply #2 on: May 11 2016, 09:15:02 AM »
635k6 is my choice
Re: Which Belt?
« Reply #3 on: May 11 2016, 09:27:36 AM »
Glen is showing a GM belt that appears to be 1620mm ~ 63.77 inches
From the Gates pdf:
K060625 .............. .............. ... 63 1/8 (1603) 13/16 (20) 40°
K060630 .............. .............. ... 63 5/8 (1616) 13/16 (20) 40°
K060635 .............. .............. ... 64 1/8 (1627) 13/16 (20) 40°
K060637 .............. .............. ... 64 3/8 (1634) 13/16 (20) 40°
K060640 .............. .............. ... 64 5/8 (1642) 13/16 (20) 40°
K060642 .............. .............. ... 64 3/4 (1646) 13/16 (20) 40°
K060645 .............. .............. ... 65 (1651) 13/16 (20) 40°
Re: Which Belt?
« Reply #4 on: May 11 2016, 09:30:51 AM »
Those are stock pulleys with the 635 Steve?
Re: Which Belt?
« Reply #5 on: May 11 2016, 09:41:30 AM »
yes
Re: Which Belt?
« Reply #6 on: May 11 2016, 05:48:04 PM »
That must mean you have the car up and running. What's the latest?
Re: Which Belt?
« Reply #7 on: May 11 2016, 07:45:06 PM »
I love my Gatorback belts.
Re: Which Belt?
« Reply #8 on: May 12 2016, 08:31:02 AM »
We were able to drive it onto the trailer.  :o
The few minutes we looked at it when we got home did nothing to support any theories to date.
Stuff spins freehand ok, the noise diminishes with the belt getting sprayed.
Once I get it quiet I'll get it good and hot, maybe apply controlled heat to the usual suspects sequentially and see if it will die. Harder to test your pump theory?
Re: Which Belt?
« Reply #9 on: May 12 2016, 10:03:36 AM »
Yea, it might have stirred up debris in the bottom of the tank from running empty. The debris can than block the sock causing the shut down, than after it sits, the debris falls away. You have to see it on your pressure gauge when it happens. Otherwise, drop the tank. Also, the finer bits of debris could get to the fuel filter. Whenever I suspect this, I cut the filter open and check.
