Author Topic: windows dont work??  (Read 13127 times)
Offline shmed
windows dont work??
« on: April 15 2016, 03:41:01 PM »
so   im trying to put this car together an now the power windows dont work pass or drivers    everything else seems ok so far
i have power to the red wire on the switch connector
is there i way i can bypass the switch so i can roll the windows up?
thanks
Re: windows dont work??
« Reply #1 on: April 15 2016, 04:59:38 PM »
I don't have power windows so I'm not sure what it looks like but a jump wire from 12v to the window motor is where I would start if you just want to roll em up.
Offline shmed
« Reply #2 on: April 15 2016, 05:08:47 PM »
ya tried that applied power  directly to the motor wiring an nothing   either side?
« Reply #3 on: April 15 2016, 05:32:12 PM »
Does it have a good ground? Might be some corrosion in there to see about. If you take the motor out will it "bench test" successfully?
Might have two bad motors. I don't know the history but if this car has been out with the windows left down you have some work ahead i would guess.
« Reply #4 on: April 15 2016, 06:23:12 PM »
The wiring to the motors floats so it  can be reversed, you need two connections
at the motor ground and hot
« Reply #5 on: April 15 2016, 06:29:15 PM »
I would expect one of them to jerk or act like a short at least. i doubt they are both dead. Mine are both originals.
Offline shmed
« Reply #6 on: April 15 2016, 07:54:30 PM »
ok   using a test light   i have power to the switch..    i also have power going to the motor both sides when   switch is applied in that direction.
took out the motor applied power to the connectors   an nothing happens ?
question though why would both be bad?
what am i missing
Offline 278CIKILLER
« Reply #7 on: April 15 2016, 08:14:11 PM »
I have two good motors if you need them ,LMK.
« Reply #8 on: April 15 2016, 08:21:19 PM »
IIRC there is a thermal cutout on the motor itself  that goes flakey:
http://turbobuick.com/threads/a-free-trick-to-help-speed-up-your-power-windows.256820/
Offline shmed
« Reply #9 on: April 16 2016, 08:15:43 AM »
Thanks Dave  good thread
i tore my motor  apart last night cleaned  the   brushes actually   cleaned it all     put it back together an  t works..
there was so much grease an oil around the   brushes an on the shaft the   brushes  ride on.
thanks for the help
Dave
« Reply #10 on: April 16 2016, 09:06:15 AM »
Nice, how about some pix. I know you must have a phone that takes pix.
Offline shmed
« Reply #11 on: April 16 2016, 05:49:38 PM »
never thought of taking pics   i could  take pics of the cleaned up version ,
