Author Topic: Race Gas Question  (Read 9407 times)
Race Gas Question
« on: April 10 2016, 06:06:01 PM »
Alright. How long is race gas good for after it's been opened. I had 5 gallons of it in the tank when my GN was stolen last Oct 4th. The idiot couldn't get it running...at first...so he poured in another 5 gallon container I had in the trailer...thin king the tank was empty. When Dan and I found the car...we drained the tank...and stored it in proper gas cans. It's been sitting for 6 and a half months. Will it still be good?
Re: Race Gas Question
« Reply #1 on: April 10 2016, 06:46:09 PM »
Mine sits all winter and starts the next season without issue. I run 110. I just ran mine for the 1st time since September 2015. I'll run this tank for our first race this weekend.
Race Gas Question
« Reply #2 on: April 10 2016, 07:09:31 PM »
As long as it's sealed up I can't see a problem.
Offline gusszgs
  • Limited quick brick
« Reply #3 on: April 10 2016, 07:13:22 PM »
Don't think it's any good past a month in plastic gas cans
Jim
1987 T Limited
« Reply #4 on: April 10 2016, 08:41:41 PM »
if you sealed it air tight, it's probably still okay, but, I would be careful and find out before going full bore.  It holds up much better than the ethanol gas
« Reply #5 on: April 10 2016, 11:11:00 PM »
I won't be going full bore. Prolly 22 PSI with low gear fuel pulled and some low gear timing added. It's currently snowing. Never raced with snow tires before. Might be a pedalfest this Saturday...
« Reply #6 on: April 11 2016, 11:36:47 AM »
I would think you're fine.  Obviously it should be in a tight container with minimum air in it.  You could always pump some out and stick a hydrometer in there and see what the specific gravity is.
