Author Topic: Barn motor and tranny swap  (Read 89298 times)
« Reply #135 on: May 06 2016, 10:59:46 AM »
Glad it's running shitty about the TR6 being the the problem. Mine works flawlessly set up with individual coils. I have seen a couple threads on the other board with a similar issue but I'm not sure what the fix was and it appears the search function is down over there.
Re: Barn motor and tranny swap
« Reply #136 on: May 06 2016, 12:35:51 PM »
Glad it helped!  Keep it as long as you need it :)
I think I have heard of another one failing some where along the line.  Probably just a fluke
« Reply #137 on: May 06 2016, 12:50:03 PM »
Mine worked without issue on the white T but not this one.  I searched every way possible on the big board and came up with nothing.  Went to google instead and found a few hits but nothing of serious note.
« Reply #138 on: May 06 2016, 12:53:11 PM »
I'd like to hold onto it till Bob gets the TR6 back to me.  I want to see what happens if I just swap in the TR6 after getting it back from him.  I shipped it this morning and he should get it Monday.
On a side note, I also shipped the 6262 this morning as well.  Bison wanted me to wait till he got back from NC
« Reply #139 on: May 06 2016, 01:54:53 PM »
It's just sitting on the shelf along aside another one...so time is no matter :)
« Reply #140 on: May 07 2016, 09:27:41 AM »
Flushed the cooling system yesterday evening. Went for a little drive and decided to try a little boost in 3rd gear. Let's just say with this little TA49 there is no lag whatsoever. Boost was there immediately. Went a little after the TC locked. It felt a good but a little... lacking at 15#s. 110 mph and o2's at 817.
Getting the wideband bung welded this morning. Super anxious for the 6262 to get back from Bison
« Reply #141 on: May 07 2016, 11:54:03 AM »
Nice work  I'm really curious to hear how that converter performs. You have it set to lock thru the chip? What speed?
« Reply #142 on: May 07 2016, 11:29:18 PM »
Chip locks the converter at 98
« Reply #143 on: May 08 2016, 06:54:56 AM »
Jason...what size exhaust housing is on that 49?
« Reply #144 on: May 08 2016, 09:07:34 AM »
Precision .63
« Reply #145 on: May 08 2016, 01:15:21 PM »
For shits and giggles I'd take it to the track and slowly bounce the boost up to 25 keeping an eye on the high gear fuel.
« Reply #146 on: May 08 2016, 09:41:58 PM »
I've got to get some tires and wheels for the track. These BFG's are great for street driving but won't do the job at the track
« Reply #147 on: May 08 2016, 09:45:42 PM »
Managed to get the wideband installed and working with the Powerlogger. Also got the Helwig rear bar installed. Waiting for the 6262 to get back from Bison before the real testing begins. I can mange without the TR6 but would prefer to have it working 100% when installed.
« Reply #148 on: May 08 2016, 10:15:12 PM »
You are going to love that swaybar!  I have one waiting to go on the wagon.
« Reply #149 on: May 10 2016, 11:52:38 AM »
Instructions state to start off in the outer most hole until I get used to it.  Which of the three holes did you end up mounting the links to?
