Author Topic: Fuel pump?  (Read 46765 times)
Fuel pump?
« on: March 02 2015, 04:40:03 PM »
What fuel pump do you guys recommend?  I'm going to be running 80's with Eric's chip using MAF and wideband O2 correction.  I currently have an XP pump, which wasn't sufficient when I bought it but Red wouldn't sell me his double pumper because he said I didn't need it. :rolleyes;   I was thinking of one of the 340 lph pumps.  What do you guys think?
Re: Fuel pump?
« Reply #1 on: March 02 2015, 07:13:20 PM »
I ran into a pressure problem going with a 340 pump. As in I couldn't turn the pressure down below 60 psi. Some guys got away with drilling out the Saginaw fittings and still running the stock lines.  I went with a -6 return line and a -8 feed.  Racetronix has a sender with the fittings already installed or you can do it yourself. I bought the sender and the lines secondhand from a member off the big board and I can't remember who sells the braided line.
Fuel pump?
« Reply #2 on: March 02 2015, 09:30:07 PM »
For what fuel and how much hp?
Re: Fuel pump?
« Reply #3 on: March 02 2015, 11:24:40 PM »
I want to be able to run around 20psi of boost on straight pump gas.  I do have alky but I want to factor of safety incase the alky fails, I know it will still get damaged but more can't make it any worse.  I'm putting out close to 500 rwhp with straight pump.  So I'd like to see how fast I can go first before turning on the alky.
Fuel pump?
« Reply #4 on: March 02 2015, 11:40:42 PM »
A conventional 255 lph will handle 10.8.  With alky,  you can handle 10.0
For a bit more, you can go with the DW or the Denso.
I don't like double pumpers but you eliminate the return line problem.
Or, you can go with a 340 and do some replacing as mentioned
Re: Fuel pump?
« Reply #5 on: March 03 2015, 01:02:47 AM »
Is the Supra TT pump no longer the 'hot ticket'?
Re: Fuel pump?
« Reply #6 on: March 03 2015, 02:16:44 AM »
Time in my sig is with a single 255 LPH pump with race gas.
Re: Fuel pump?
« Reply #7 on: March 03 2015, 06:52:20 AM »
I like my dw200 so far.
Re: Fuel pump?
« Reply #8 on: March 03 2015, 09:19:47 AM »
That is what I called the Denso pump...It's still probably the best quality pump out there...imo, at least :)  As you know, it is a little more of a pain to install because of the diameter but no big deal
Re: Fuel pump?
« Reply #9 on: March 03 2015, 02:24:18 PM »
I can't see a 255 supplying a enough pump gas for a 10.8 in a 4100lb car in a lighter one absolutely.  I am running mid to high 11's on pump with my 50's but they are maxed out.  Now that I have the 80's Eric said I don't have enough pump to supply them unless I'm on alky.
I was also thinking a big single pump would be much simpler.
Re: Fuel pump?
« Reply #10 on: March 03 2015, 04:46:42 PM »
Jack at Racetronix sells the 340 LPH pump already installed in the SS hanger...it's plug-n-play. He also sells the larger supply/return line kit...which is also plug-n-play. He's located in Toronto...so shipping is easy. He usually has my stuff to me overnite.
Re: Fuel pump?
« Reply #11 on: March 03 2015, 05:06:18 PM »
That is where I got my 80's from.  I would definitely buy from him, he's a good guy!
Re: Fuel pump?
« Reply #12 on: March 03 2015, 05:23:57 PM »
Just checked Erics site...it appears he's no longer selling 80 lb injectors. Gonna order them from Jack.
Re: Fuel pump?
« Reply #13 on: March 03 2015, 10:41:37 PM »
Good point...    On the upside if forces one to inspect the hanger very closely and fix cold solder joints and fortify the fuel level rheostat.  :)
Re: Fuel pump?
« Reply #14 on: March 04 2015, 04:15:57 PM »
That sounds like the ticket to me. :atbeer:
