Author Topic: Tonite...By The Numbers  (Read 9497 times)
« on: September 13 2014, 10:21:33 PM »
Race Length-1/8th Mile
Temperature-48 Degrees
Humidity-61 Percent
ET-7.3
MPH-99
60 Foot-1.79
Reaction Time-.519
Boost 22 LBS
Flash Stall-3800
1st Gear Shift Point-5200
1st Gear Fueling-831
1st Gear Timing-26.8
2nd Gear Shift Point-5550
2nd Gear Fueling-791
3rd Gear Timing-26.1
3rd Gear Fueling-791
Trap RPM-5550
"Just the fax ma'am...just the fax"
Re: Tonite...By The Numbers
« Reply #1 on: September 14 2014, 12:53:20 AM »
is the converter a bit loose?
« Reply #2 on: September 14 2014, 01:17:42 AM »
It flashes fairly high on launch. It's a 16930...suppos edly they stall at 3000 at zero pounds boost. I was up against a Sportsman class Mustang tonite...and you can tell by the reaction time it spooled fairly quick. I rolled into the lites last...and they dropped 'em. The laptop I have for the track doesn't have internet. In the morning I'll transfer the file to this laptop...and I'll send it to you...and give me your take on it.
« Last Edit: September 14 2014, 01:34:55 AM by Scoobum »
« Reply #3 on: September 14 2014, 01:32:01 AM »
One other thing Steve. This convertor came out of a 9 second GN from Montreal. It may very well have been cut open and reworked. Jack Cotton does a ton of work for this guy.
« Reply #4 on: September 14 2014, 01:43:35 PM »
Good to see you beating on it in sept! Cooler air has got to be helping some too.
« Reply #5 on: September 14 2014, 02:33:19 PM »
It rained the entire day here...and it dropped to 48F when I made my run. I could see my breath it was so cold and damp. Temps are suppose to moderate this week...and I'm gonna get out Friday nite and dial the low gear fueling and timing in.
« Reply #6 on: September 14 2014, 03:18:08 PM »
16930's used to flash to 3400-3500 as I recall.   they have always been a damned good converter.  Just seems to me that it is flashing a bit high for a 6262 and may be hurting the first part of your run
« Reply #7 on: September 14 2014, 04:32:45 PM »
You've been at this longer than I have...so yer' prolly correct about it flashing a tad high. AC makes a solid convertor...an d used ones can be had for a song these days for those on a budget. Wish conditions were better last nite...as I wanted to pull low gear fuel and add a tad of low gear timing. Only an idiot like me would be out in cold, damp, and windy conditions like last nite.
« Reply #8 on: September 14 2014, 05:31:47 PM »
It looks a tad rich.  I would add boost before timing,  I think since you already have a lot of timing for a bigger turbo
« Reply #9 on: September 14 2014, 06:00:54 PM »
I run 110 race gas...and those timing numbers are Erics 110 chip defaults. Low gear 02's are way too rich...and I'll be pulling a whack of fuel out of low gear Friday nite. I wanna set the car up at 7.1. Any faster...and I won't get any races. These guys are onto me. :)
Offline firebird_1252
  • PSI: -1
« Reply #10 on: September 15 2014, 08:01:46 AM »
Why not try out e85?
87 GN- :D
« Reply #11 on: September 15 2014, 10:54:03 AM »
That's the way to do it as fast as your allowed to go!
« Reply #12 on: September 15 2014, 05:13:46 PM »
Rob...it's not readily available up here. Closest E85 station to me is in Ottawa...bout 3 hours away.
  • PSI: -1
« Reply #13 on: September 15 2014, 06:07:30 PM »
Damn. Seems like here it's spotty but available.
87 GN- :D
