Author Topic: New truck.. w00t!  (Read 17235 times)
New truck.. w00t!
« on: September 03 2013, 06:07:25 PM »
Shitty pic - I will have better ones once I pick it up. :D
2007 F150 Lariat 5.4l, 20" factory rims,  193k - loaded.
I gave a bit over 6k for it. I bought it from a buddy of mine, I remember when he bought it new. 70% of the mileage is highway - it was his work truck for the most part. Blue Book, etc is a good bit higher..
It has new coil packs,. spark plugs, and radiator. Tires are beat - they aren't cheap - 275/55-20.  :shock:
E85 is shit -
Offline Jeff
  • The Thread Killer....
Re: New truck.. w00t!
« Reply #1 on: September 03 2013, 06:44:40 PM »
Nicee mark congrats.   Even better you purchased it from.a friend w that high milage..  :rock: :atbeer: tood bad its a ferd lol
« Reply #2 on: September 03 2013, 06:52:36 PM »
Trucks sure are handy when you need one.  Congrats on the truck.
« Reply #3 on: September 03 2013, 06:53:16 PM »
New plugs and coil packs is a huge bonus.
« Reply #4 on: September 03 2013, 08:12:07 PM »
That's the main reason I didn't quibble too much on the price. I told him I wanted to pay 6k, he wanted a bit more. It purrs, even with the mileage.
I will need to hit it with a buffing wheel, it needs a tire pressure sensor (one has failed), and the battery may be weak. I don't expect all roses, but it will be a damn sight better than the Eldo.
« Reply #5 on: September 06 2013, 08:50:40 AM »
Picked it up last night..
Whoa! This thing is huge - but drives great. So many cool gadgets to fiddle with. :)
« Reply #6 on: September 06 2013, 09:02:02 AM »
It has a cover? that's worth a ton o' money itself. Ford trucks have always been good for me.
Offline gnonyx
« Reply #7 on: September 06 2013, 09:02:25 AM »
Congratulation on your new arrival, I don't care what state you're from, everyone needs a pickup truck. Soon will be in the process of looking for a good deal as well. :cheers:
« Reply #8 on: September 06 2013, 12:29:27 PM »
Yep - it has a full fiberglass lockable tonneu cover..
Easy to take off, just 4 aluminum bed rail clamps.
It has a factory Ford bedliner too.
« Reply #9 on: September 06 2013, 01:37:51 PM »
The FORD bedliner is great!
« Reply #10 on: March 24 2014, 11:13:35 AM »
Update:
Still loving this truck - what a pleasure to drive.
I replaced the battery with an 800CCA unit, and replaced the two worn front tires and TPMS sensor - now all 4 tires match - the rears were in good shape already.
The biggest issue I have is the windshield washer sprayers keep getting clogged - seems there's an issue with these doing that, I need to remove/clean the reservoir, and replace a disintegrating gasket to keep the trash out of the system.
Not a big deal!
« Reply #11 on: March 24 2014, 11:52:19 AM »
300K on my F150....they are hard to beat
« Reply #12 on: March 24 2014, 12:00:46 PM »
If I can own a vehicle and my biggest worry is the windshield squirters - I am doing OK.
« Reply #13 on: March 24 2014, 01:42:02 PM »
I would say so~
« Reply #14 on: March 24 2014, 03:46:36 PM »
I still need to yank out the back seat so I can get the door code.. Meh..
