Author Topic: New Paint!!  (Read 33977 times)
Re: New Paint!!
« Reply #15 on: July 11 2012, 04:39:29 PM »
question, the rims got primer dust/overspray on them. Not really bad but i want to get it off. What works? i've tried gas and then paint thinner but no success? Help!!
Offline gbsean
Re: New Paint!!
« Reply #16 on: July 11 2012, 07:23:53 PM »
have you tried a clay bar,,, or 000 steel wool and thinner will work...thats how i cleaned up overspray on my stainless moldings on my 67...works on chrome too...
Re: New Paint!!
« Reply #17 on: July 12 2012, 08:30:35 AM »
What kind of rims?
Re: New Paint!!
« Reply #18 on: July 12 2012, 12:20:02 PM »
Not sure of brand of rims, they are painted black in the center with a shiny aluminum, not chrome, outer rim. Claybar a good idea, I think steel wool will work on the outer rim but afraid to try it on the black part, might have to though, and then use some different polish's to get shine back.
Thanks!
Re: New Paint!!
« Reply #19 on: July 12 2012, 01:12:25 PM »
Thanks!
GNX replica rims? Gentle use of steel wool will get rid of the overspray (and likely, the clear coat), you may have to get the centers repainted.
Have you talked to the paint shop about it?
Re: New Paint!!
« Reply #20 on: July 19 2012, 10:53:05 AM »
Not great pics but here it is
Re: New Paint!!
« Reply #21 on: July 19 2012, 11:04:25 AM »
Looks good.  Those tires are pretty wide in the back!!
Re: New Paint!!
« Reply #22 on: July 19 2012, 11:43:12 AM »
Looks great. You'll get the stares on the street now :atbeer:
Re: New Paint!!
« Reply #23 on: July 19 2012, 12:23:20 PM »
VERY nice - love the wheels and paint job!  :rock:  :powersix:  :rock:  :powersix:
Re: New Paint!!
« Reply #24 on: July 20 2012, 08:35:42 PM »
Nice!
