Author Topic: issues at low boost  (Read 20042 times)
Re: issues at low boost
« Reply #15 on: March 02 2012, 07:38:58 PM »
I would guess the surge is worse because it is spooling faster due to less alky.  Alky tends to put a damper on spool.  Don't know if you can tell the difference in spool?
Never seen surge quite that bad.  Usually took a bit more than half throttle when I had the problem to get around it.
The 02s see, to be about right in my experience and with what Eric suggests...I guess some playing is in order
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
« Reply #16 on: March 02 2012, 07:54:06 PM »
I say that the surge is worse but it seems like instead of surging at 10 psi it surges at 15-18 now at atleast half throttle  :icon_confused:
« Reply #17 on: March 02 2012, 08:00:45 PM »
Kinda strange...wond er if it is getting too lean at that point?  Can you see the O2s just before it happens?  Most of the time, I have seen the problem between 0-12 psi or so
Try something else, unplug the cam sensor after you start it and then go drive it...see if that is any different.  Sometimes a cam sensor can make one act up.  I always install the sensor and turn it at least an 1/8" ccw more than the location where the voltage dropped.  Remember it will not restart once you shut it off until you replug it
